Author Topic: DSG Dual Mass Flywheel - where to buy ?  (Read 13474 times)
Offline PaulGTI
Re: DSG Dual Mass Flywheel - where to buy ?
« Reply #15 on: October 07, 2012, 11:12:12 am »
What symptoms did you have that made you get yours changed ?
.... x 2  :smiley:
X3 mine rattles if that helps chaps.
Mine has a slight rattle and noticeable knocking / whine at low revs ( I think it's always there but just more noticeable at slow speed as there's not much road noise) but my gear changes are smooth and no performance loss at all.
h4rdy
« Reply #16 on: October 07, 2012, 11:17:06 am »
Mine does that. Not to bothered. Alex noticed it first.
Offline PaulGTI
« Reply #17 on: October 07, 2012, 11:49:02 am »
The thing that worries me is the vibration of the DMF having an adverse affect on the splines and shaft of the DSG internals
« Reply #18 on: October 07, 2012, 01:44:20 pm »
Surely any audible vibration or 'rattle' of the DMF is not normal in the DSG and therefore needs attention?
h4rdy
« Reply #19 on: October 07, 2012, 01:46:09 pm »
Yes your probably right Robin.
« Reply #20 on: October 07, 2012, 01:49:26 pm »
....See! Sometimes I can be Captain Sensible  :wink: (not very often though)................ AND I'M ALWAYS RIGHT!
h4rdy
« Reply #21 on: October 07, 2012, 01:51:08 pm »
It won't be any time soon though.......
Offline PaulGTI
« Reply #22 on: October 07, 2012, 02:12:14 pm »
Yeh definitely, it seems a common failure on early cars (2005 & 2006) I think. Vw then upgraded them to stronger ones.
I did a DSG oil change (fairly easy to do) in my early diagnosis to see if it would help but didn't. Which led on to me investigate some more and come up with the DMF. A good way to check if its worn is to take off the starter motor (and battery tray so you can see what your doing) then try and move the front / first part of the flywheel and if its worn it will move and the second part behind it will stay still (the part with the teeth that the starter motor turns). There will be a little bit of play as standard though which I think is roughly 10-15mm, anymore and it's probably worn and if it rattles back and fourth then it's definitely gone. Hope the info helps anyone in the future.
« Reply #23 on: October 07, 2012, 04:32:18 pm »
That is helpful, Paul  :happy2:
My Mk5 GTI is a 05-build, 06-spec now at 104k miles with no audible signs of this issue so far.
h4rdy
« Reply #24 on: October 07, 2012, 04:36:52 pm »
82k 2007 and been like it since 65k at least! Alex at AKS noticed it.
TBH I would want the LSD done while the 'box is out so it can wait.
I need to find another cheap DSG box as well first.
Not to bothered, it works :rolleye:
« Reply #25 on: October 07, 2012, 04:49:40 pm »
....You're just looking for any excuse to get a LSD  :evilgrin:
I'm sure you already know that it's a great mod even if relatively expensive.
h4rdy
« Reply #26 on: October 07, 2012, 05:41:08 pm »
I went out in the 'Blue Devil' at AKS the other week and yes it was good.
But I also realised how good mine is set up to.
Alex said it handled quite well so a LSD will just add to my setup.
There is one really serious problem that  I have to negotiate first.............................NO MONEY!
And the fact that I want/need a Turbosmart E-Boost 2 and AEM WMI first.
Plus a DSG service and a service.
Injectors fitting.
Baby due.
Shall I go on?
Offline cass
« Reply #27 on: October 07, 2012, 09:54:53 pm »
quite hard to explain the symptons.....it only did it when the gearbox was in neutral or not under load , and it was like a juddering noise coming from the box.The pattern was never the same, Sometimes it would do it 4 times sometimes 2......i did a load of searching on the net and found a video on youtube with the same noise as mine. When i took it into awsome for a cambelt change they told me it was on its way out . Hopes this helps....not a great explaination really .
Offline cass
« Reply #28 on: October 07, 2012, 10:01:14 pm »
Just found the video....youtube ....2006 vw tdi dsg-confirmed dual mass flywheel failing.....and i remembered that when i turned the car off it would rattle its nuts off
Offline vRSAlex
  • -Receive: 253
« Reply #29 on: October 08, 2012, 04:34:12 pm »
VW retail is £721.94.  Best I can do one for £615 delivered.
Follow AKS tuning on Facebook
