Author Topic: Door controls and central locking not working  (Read 3136 times)
Offline 81lly
« on: October 04, 2012, 06:49:58 pm »
My central locking and door controls don't work, I'm able to power up and down the rear and front left door window but the rest don't work. I disconnected the battery and reconnected to see if that did anything but that didn't help. I've checked all the fuses in engine bay and on driver side by door and they are all fine.
I did a vcds scan this is what came up
Thursday,04,October,2012,17:34:29:16263
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVWZZZ1KZ7W208404
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Cannot be reached 1100
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 DF    HW: 03G 906 018 DF
   Component: R4 2.0l PPD1.2      4345
   Revision: --H42---    Serial number: VWZ7Z0G7036484
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 6CDCBF524FB47078EDD
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0023170
   Shop #: WSC 01279 785 00200
   VCID: 73EEA42E128AAF802C7
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1K0 820 047 GL
   Component: Climatic PQ35   120 0606
   Shop #: WSC 00000 000 00000
   VCID: 74ECA7321784A8B835D
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006752560
   Coding: E5898F270004150F471400001400000000087F075C0001
   Shop #: WSC 12345 785 00200
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 120207 020  0501
   Coding: 00038805
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     260207 020  0105
   Coding: 00208933
   Shop #: WSC 12345
4 Faults Found:
02394 - Parking Light Left Front (M1)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 10
                    Reset counter: 155
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.50 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02395 - Parking Light Right Front (M3)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 13
                    Reset counter: 153
                    Mileage:
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.60 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01334 - Door Control Module; Rear Right (J389)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 60
                    Reset counter: 115
                    Mileage:
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.75 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01331 - Door Control Module; Driver Side (J386)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 60
                    Reset counter: 115
                    Mileage:
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.75 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD11XYLA
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D7A4216644E29F00A3
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           056 0111
   Coding: 0010604
   Shop #: WSC 12345 123 12345
   VCID: 7AF0890A35E0DEC86F1
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Shop #: WSC 00000
1 Fault Found:
00380 - Special Vehicle Control Module (J608)
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K0 920 963 B    HW: 1K0 920 963 B
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0G7036484
   Coding: 0001403
   Shop #: WSC 00135 210 91511
   VCID: 2B5E7C4E8A3AB740A47
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 210207F2000876
   Coding: 3D3F074007000003
   VCID: 2F66685EBE22CB6088F
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 110
                    Mileage:
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:01
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 110
                    Mileage:
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:01
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1610
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 356A5A365C7EF1B0C23
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            000 -  -
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0203
   Revision: 00020000    Serial number: 00000000000000
   Coding: 999002005103087F2D0484057008DFC690FCA0
   VCID: 830E74EEC22A1F00BC7
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 951 178
   Component: Neigungssensor  001 0101
   Component: Innenraumueberw.001 0101
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 115
                    Mileage:
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:01
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 115
                    Mileage:
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:01
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Component: Tuer-SG         005 0986
   Coding: 0000948
   VCID: 3A70490A75601EC82F1
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         005 0912
   Coding: 0000144
   Shop #: WSC 01279 785 1012552
   VCID: 387453024B6C0CD8D95
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D5A7256B42EB970BA3
End   ---------------------------------------------------------------------
Anyone know what the problem could be?
Offline 81lly
Re: Door controls and central locking not working
« Reply #1 on: October 04, 2012, 08:47:17 pm »
All fixed now   :pomppomp:
