Author Topic: Rear Doors  (Read 967 times)
Offline andrewparker
  • -Given: 32
  • -Receive: 78
Rear Doors
« on: June 14, 2009, 11:29:46 am »
Hi all, the rubber suction pad off some sun blinds on my rear window have been pulled into the door.
I don't fancy taking the door panel off, however, is there a chance it could cause problems at some point? At the moment the window is operating fine and there is no noticeable noise, so if I can get away with it I'd rather leave it down there...
Re: Rear Doors
« Reply #1 on: June 14, 2009, 05:04:19 pm »
I cant see why it would cause a problem in their unless every time you move the window up and down it wedged in a place that causes a lot of resistance on the motor, it should be fine i reckon.  :smiley:
