Author Topic: Luxuary pack moving passenger mirror?  (Read 1539 times)
Offline Rustybear
  • -Given: 243
« on: October 06, 2012, 08:42:47 pm »
Right, my car has the luxuary pack 1 fitted I.e. rear reading lights, folding mirrors, high line display, cruise, heated seats, auto lights etc. However, I believe the option also meant the passenger mirror moved down when reverse was engaged to allow you to see the kerb. When engaging reverse my passenger mirror doesn't do this so is their something I should be looking, doing or setting? Help!!!  :smiley:
Offline richtung
  • -Receive: 56
Re: Luxuary pack moving passenger mirror?
« Reply #1 on: October 06, 2012, 08:56:38 pm »
Hello bear,
On the highline display, go into the settings menu and make sure the option for the parking mirror function (cant remember the exact terminolgy) is activated.
On the drivers door, make sure the knob to adjust the wing mirrors is set to "L".
Hope this helps.
Rich
Offline damoegan
« Reply #2 on: October 06, 2012, 08:59:56 pm »
It ususaly needs to be activated with VCDS.. To use you need to have the morror adjust know set to the passenger side  :happy2:
scottm72
« Reply #3 on: October 06, 2012, 09:11:05 pm »
Hello bear,
Hope this helps.
Rich
thanks for that rich, advice wasnt for me but great i didnt know my pass mirror did that lol,,,, works a treat,,, yep stick it in L, query though,,, i understand i have to physically put the wing mirror onto L, and by the looks of it when i am finished reversing i have to put it back to the middle setting to get the mirror back to normal hight in mine ? surely this should be automatic when you take the car out of reverse ?
also you say go into the high line setting ? what exactly is the high line settings ? is it just the normal trip computer cause i cant see any settings etc, can i poss have the lux pack with no high line settings ? other quest as well,,, i understand the other setting on the wing mirror controls is for folding / and heated mirrors but when you go into the car and your windscreen is frosty you press the defrost button on the climate control but the symbol looks the same as the rear screen heaters,,,, you would think with a similar icon it would mean the front windscreen is heated also but it isnt--- right ---?
sorry for all the noob questions but still trying gto figure out my toys lol and thanks again
Offline Rustybear
  • -Given: 243
« Reply #4 on: October 06, 2012, 09:23:23 pm »
Thanks for that. Just nipped out to the car to give it a go and no joy unfortunately  :sad1: really appreciate your feedback though  :smiley:
Offline damoegan
« Reply #5 on: October 06, 2012, 09:26:58 pm »
It will prob need activating with VCDS, mine had to be activated..
Offline Rustybear
  • -Given: 243
« Reply #6 on: October 06, 2012, 09:38:34 pm »
Thanks, what the vcds please?
Offline richtung
  • -Receive: 56
« Reply #7 on: October 06, 2012, 09:41:22 pm »
Hello bear,
Hope this helps.
Rich
thanks for that rich, advice wasnt for me but great i didnt know my pass mirror did that lol,,,, works a treat,,, yep stick it in L, query though,,, i understand i have to physically put the wing mirror onto L, and by the looks of it when i am finished reversing i have to put it back to the middle setting to get the mirror back to normal hight in mine ? Nope, just leave it in "L", when you go forwards and exceed 10kph (round abouts when the anti hijacking feature kicks in, the mirror returns back to the upright position surely this should be automatic when you take the car out of reverse ?
also you say go into the high line setting ? what exactly is the high line settings on mine (i have the steering wheel buttons), i can access a settings menu on the screen to change various settings such as lights at home, anti hijack and various other ones. ? is it just the normal trip computer cause i cant see any settings etc, can i poss have the lux pack with no high line settings ? not sure about this other quest as well,,, i understand the other setting on the wing mirror controls is for folding / and heated mirrors but when you go into the car and your windscreen is frosty you press the defrost button on the climate control but the symbol looks the same as the rear screen heaters,,,, you would think with a similar icon it would mean the front windscreen is heated also but it isnt--- right ---? you have one button for activating the rear windscreen demister and one for directng the airflow for the fron windscreen. the buttons should work indendently from each other
Offline damoegan
« Reply #8 on: October 06, 2012, 09:41:33 pm »
VAG-COM in old money http://www.ross-tech.com/
scottm72
« Reply #9 on: October 06, 2012, 09:48:33 pm »
Hello bear,
Hope this helps.
Rich
thanks for all your help, that makes sense now about the mirror moving on its own, i dont have stearing wheel controls so ??? do i have highline ????  i assume i would have some way of controlling the coming home lights etc,,, may have to post a thread on this one,,,, many many thanks for your help buddy :happy2:
Offline vag12
« Reply #10 on: October 07, 2012, 12:15:12 pm »
I would like to activate this via VCDS does anyone know how to do so?
« Reply #11 on: October 07, 2012, 01:39:16 pm »
What year model cars do you guys have as the feature was only introduced in 07 and later cars with rear park sensors and/or luxury pack.
Offline Rustybear
  • -Given: 243
« Reply #12 on: October 07, 2012, 04:59:02 pm »
Mines a 2006 so may well not be able to do I then
Offline damoegan
« Reply #13 on: October 07, 2012, 05:38:35 pm »
Mine is a 56' plate 2007 and has it..
