Author Topic: V9 Maps - Western Europe  (Read 20791 times)
Offline alexperkins
  • -Receive: 99
Re: V9 Maps - Western Europe
« Reply #30 on: October 21, 2012, 09:40:13 am »
I take it as Im running 2760 with V7 I need to update the firmware and then the maps??
For the firmware what can I up date to as I know certain RNS's can only go to certain firmwares, mines an RNS Rev C LED so does anyone know what I can safely upgrade to?
Correct - you should update for the best results. You can go up to the latest on a Rev B or Rev C RNS with no problem. Get it here http://www.my-gti.com/3354/volkswagen-rns-510-firmware-upgrade-to-version-4020-4024-4026-4028 and burn at a 1-2x speed
« Last Edit: October 21, 2012, 09:43:20 am by alexperkins »
Offline alexperkins
  • -Receive: 99
« Reply #31 on: October 21, 2012, 09:40:55 am »
My maps are showing as 7920 and when i re insert the maps disc, nothing happens...
Looks like youve updated
I would do the firmware upgrade though to benefit from all the new features and the new POI database.
You will need to reload the maps again after however.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #32 on: October 21, 2012, 09:44:32 am »
Any idea why yours is showing at V7970 but mines only V7920?
Offline alexperkins
  • -Receive: 99
« Reply #33 on: October 21, 2012, 09:45:19 am »
7920 and 7970 are both V9 maps
The difference between them, is that 7970 has all the speed cameras and red light cameras on it too  :happy2:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #34 on: October 21, 2012, 10:05:24 am »
Thanks Alex!
Offline Squeeguk
« Reply #35 on: October 21, 2012, 10:19:21 am »
I installed the one with the speed cams, etc. but driving up the A3 yesterday past loads of cameras and not one blip on the map?? Are the cameras for UK too, or elsewhere?
Offline alexperkins
  • -Receive: 99
« Reply #36 on: October 21, 2012, 10:21:29 am »
Just for the UK but it may be other countries
Have you turned it on in Setup > Map > Map Details > Car and Travel > Other > Speed Cameras
Offline Squeeguk
« Reply #37 on: October 21, 2012, 10:33:39 am »
Yep, definitely on in POI's. The speed and traffic light cameras are both on the list.
Offline alexperkins
  • -Receive: 99
« Reply #38 on: October 21, 2012, 10:34:16 am »
I found on mine I had to eject the disk, turn the POIs off then on again for them to come back as they vanished first time  :happy2:
Offline Squeeguk
« Reply #39 on: October 21, 2012, 10:38:13 am »
Interesting. I have tried rebooting mine, clearing them then choosing them again, then rebooting again, etc. Still nothing. It's all very annoying.
Offline alexperkins
  • -Receive: 99
« Reply #40 on: October 21, 2012, 10:38:57 am »
What firmware are you on?
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« Reply #41 on: October 21, 2012, 02:01:09 pm »
Slight hijack here-apologies.
My original RNS 510 'A' has 2760 firmware and V8 Maps which I updated last year courtesy of Carl's excellent guide. I've bought V9 Maps but am concerned the unit will fail or not work properly if V9 is loaded. Scott assures me otherwise but after reading this thread I'm not so sure.....
Anyone please?
PR
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #42 on: October 21, 2012, 02:12:10 pm »
The risk is fairly low for updating maps
The worst thing that can happen is you loose your current map that is stored on the hard drive. This would happen if the DVD drive struggles to read all the info on the new map DVD. Some drives can be fussy what DVD brand they like.
As most disk that are available are copies from either ebay, friends or other forum members it is likely that some people will have issues.
I have a brand new unit at the minute that I have tried loads of copied dvds in and it fails to load the v9 maps, but as soon as I put the original V6 disk in it loads first time
Cluster and Key coding
Location Great Yarmouth
Offline Mr Savage
« Reply #43 on: October 21, 2012, 03:03:02 pm »
Interesting, how much are VW charging for the V9 disk & does it include the latest firmware update also?
Does it resolve the Bluetooth streaming issue?
Offline Squeeguk
« Reply #44 on: October 21, 2012, 03:36:48 pm »
Running 5218, which I installed prior to updating the maps.
