Author Topic: V9 Maps - Western Europe  (Read 20813 times)
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: V9 Maps - Western Europe
« Reply #60 on: October 24, 2012, 06:22:47 pm »
Updated my firmware to 4120 and re installed V9 maps. Highlighted the speed cameras and traffic light cameras in POIs but they are not coming up on my map from scrolling the map around. My map version is still showing up as V7920 as well despite re installing after the new firmware
Also my bluetooth (5k0) doesnt seem to want to work anymore. Not had enough time to look at it properly though. Il try unplugging it and plugging it back in again
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« Reply #61 on: October 26, 2012, 12:17:29 am »
I took the plunge and tried to upgrade my RNS 510 'A' running 2760 FW with V9 map data but it refuses to load. It doesn't ask me to save to the hard drive (it did once actually) and then either spits the disc out or brings up a disc error message.
It seems to be reading the data sometimes but just not saving it.  Is it because its such an early machine? Any ideas chaps?
Thanks.
« Reply #62 on: October 26, 2012, 08:52:13 am »
Thanks.
What make of dvd are you using and did you burn it at a slow speed?
Apparently the disc likes to burnt bookmarked as dvd-rom for compatibality, something you can do with Nero of if your drive's firmware allows it.
Offline alexperkins
  • -Receive: 99
« Reply #63 on: October 26, 2012, 12:23:45 pm »
Youll need to use the V7970 maps Joe - 7920 doesnt have speed cams
Offline alexperkins
  • -Receive: 99
« Reply #64 on: October 26, 2012, 12:24:29 pm »
Thanks.
Seconded
High quality DVD-DL such as verbatim burnt at 1x or 2x is the best approach
Offline galaxie500
  • -Given: 38
« Reply #65 on: October 31, 2012, 06:02:10 pm »
The disc was a Verbatim Dual Layer DVD+R I believe but it continually ejected itself and showed a disc error.  I've since burnt a TDK Dual Layer version and so far its staying in the machine at least.  Should I see some kind of progress bar? I pressed eject and it said it was downloading data with 'Eject' 'Notify' and 'Back' buttons below. Does this sound right?!
Thanks.
PR
Offline Antvw
« Reply #66 on: November 02, 2012, 09:44:00 pm »
Hi I have a rns 510 b version. With 2760 firmware.
If I updated to v9 maps would I get speed cameras on the maps? Also by updating the maps does this update the speed limits too?
Thanks for any help
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #67 on: November 03, 2012, 09:14:58 am »
You'll only get speed cams if someone has modified the map.
Personally I prefer to use a virgin map and if I want to add POI's I can put them on SD.
Sent from my iPad using Tapatalk HD
Stu...
Offline skard
  • -Receive: 245
« Reply #68 on: November 03, 2012, 09:20:10 am »
Have you ever tried getting the pocketgpsworld database on the RNS?
Can POIs beep or just visual warnings?
Ta
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #69 on: November 03, 2012, 09:26:02 am »
Yes commercially available databases can be used however so far as I am aware it's visual only.
Stu...
Offline Antvw
« Reply #70 on: November 03, 2012, 09:28:47 am »
cheers for your reply. Ive just seen the tutorial to add speed camera through sd card.
When I update to the latest maps will the speed limits also change? As a few roads and speed limits have changed and my rns 510 obviousoly doesnt know. Im unsure on what map version I have but found this on the secret menu... "Map version HDD    7551"
cheers for your help
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #71 on: November 03, 2012, 09:35:07 am »
The speed limits are tied with the map data from Navteq so its accuracy is determined by their data. V9 database is from Q1 2012.
Stu...
Offline Antvw
« Reply #72 on: November 03, 2012, 09:37:50 am »
thanks
Offline galaxie500
  • -Given: 38
Re: V9 Maps install on RNS510 Rev A update
« Reply #73 on: November 04, 2012, 11:03:47 pm »
After buying V9 maps and their absolute refusal to load, I tried again with a disc I burnt and success is mine! I'm still on FW2760 and unless someone tells me different, my Rev A RNS 510 can't have it's Firmware upgraded any further? Can't say I see many changes to the mapping and I wonder if I'm actually seeing less road name information.
Interested to hear comments.
Thanks for your help.
PR
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #74 on: November 04, 2012, 11:18:53 pm »
As said at this time, any V9 map can't be genuine
only Eastern Europe is available as V9 which doesn't incude benelux, Uk, Ireland, France, Spain and Portugal
So I would guess any V9 advertised as V9 WE is a modified version of the Eastern V9 with the countries added to that
Cluster and Key coding
Location Great Yarmouth
