Author Topic: Painting hubs and calipers...  (Read 3887 times)
Offline trs888
  • -Given: 17
  • -Receive: 20
Re: Painting hubs and calipers...
« Reply #15 on: October 11, 2012, 11:40:35 pm »
yeah man that looks cool,,, how long did you have to leave your car on a jack for, was thinking about that and was a bit worried about leaving the car outside for many hours up on a jack, cant get my car into my garage as my driveway slopes down and garage is flat so i would scrape the front floor of the car,,, stupid house builders.
i only have the stupid supplied jack that comes with the gti so i think i will buy a trolley jack
i got one of these,
http://www.ebay.co.uk/itm/Brand-New-Arcan-3-0-Ton-Low-Lift-Trolley-Jack-Professional-/300790660514?pt=UK_Lifting_Moving_Equipment&hash=item4608853da2
fit under a slammed car too. well worth the money
if you dont get that one, just make sure you get one with a rubber pad. if you use the pinch welds to jack up the car it will prolong their life, unless you get a AUDI TT jacking kit like i did.
in fact I'm gonna invest in another one of those.
also, i got this caliper painting kit from awesome GTI.
http://www.awesomegti.com/folia-tec-caliper-colour-kit
decent price, i did my R32 brakes with 2 coats, front and backs and still have enough for a third coat.    used an artists brush with soft bristles, made painting much easier.
« Last Edit: October 11, 2012, 11:44:12 pm by trs888 »
Offline chowgar
« Reply #16 on: October 11, 2012, 11:52:08 pm »
I used the jack in the boot then a set of axle stands... wasnt up on stands too long, did them over 2 weekends...
scottm72
« Reply #17 on: October 12, 2012, 02:56:35 pm »
i got one of these,
cheers for that dude, i will prob buy the one you found, as for the caliper kit - my calipers actually look almost brand new so i will just clean them when i take the wheels of to paint the hubs,,,,, is the best way to clean the calipers whilst still on the car with brake cleaner spray do you think as mine just look like they need a wipe down but is it ok to completelly spray them with the cleaning spray first, thanks for the link
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #18 on: October 12, 2012, 07:50:18 pm »
I just used the supplied jack and left each hub for a bit less than 1 and a half hours before putting the wheel back on.
Offline Sug
« Reply #19 on: October 12, 2012, 10:22:45 pm »
Black satin Hamerite for the hubs  :happy2:
+1  :happy2:
EDITION 30 GONE, MK6 R GONE........AUDI 8V S3.....Stock for now
scottm72
« Reply #20 on: October 12, 2012, 10:54:49 pm »
[/quote]
yeah but lets admit here the supplied jacks aint very safe,,,, def worth investing in a trolley jack, soooo much safer
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #21 on: October 13, 2012, 10:23:24 am »
[/quote]
Wasn't worth buying a jack just for this job. Supplied jack was fine, was made to perform a function and it does it. Having said that, I obviously wouldnt work underneath it!  :laugh:
scottm72
« Reply #22 on: October 13, 2012, 04:13:35 pm »
[/quote]
dont get me wrong i agree with you the supplied jack is there to serve a function and it does it ( just ) im only saying that if you need to get a wheel of in future for any reason, painting hubs, cleaning backs of wheels, changing tyre, cleaning behind interier trims etc etc etc then it is usefull,,, also the crank bar is very poor you get in any car and dont fancy being at the road side at 1 in the morning or something in pouring rain and freezing cold trying to get a partially seized wheel of with a one arm crow bar thats all im saying.
a trolley jack in the garage and a crank torque wrench in the boot would obviouslly be safer and a lot easier
s**t just reminded myself to buy a torque wrench lol  :surprised:
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #23 on: October 14, 2012, 08:32:54 pm »
Quote
when i painted the GTI calipers on the car, i used a steam cleaner on mine, a screwdriver to get rid of flaking paint and also a wire brush to smooth the caliper out.
im not sure if the brake cleaner will do any damage to anything around the brakes, or copper grease that sits where the brake pads are. best to ask your vw dealer or mechanic.
i think i heard somewheree that you shouldnt spray it onto the disks as it will act as a lubricant and not stop when you want to. again - best to check at a garage.
the second time i was painting R32 Calipers before they were fitted so i did use the cleaner on them.   hope that helps!
scottm72
« Reply #24 on: October 14, 2012, 09:23:42 pm »
thanks for that, yeah i know about not putting the brake cleaner on the disks as i done it 3 weeks ago on the wifes car and took a day to wear off,,,, lost about 40% efficiency on the brakes - oops
i think my calipers just need a clean,,, my sons wet bum wipes are a multi task thing lol,,, thanks for your help
