Author Topic: Rear Discs & Pads  (Read 2513 times)
Offline AnSGTI
  • 2012 GTI Edition 35
Rear Discs & Pads
« on: October 11, 2012, 05:05:49 pm »
Apologies if this is a common question but I got lost in topics about upgrades over OEM when using the search function
My rear disks and pads will soon need to be replaced on my ED30. I just called VW and they quoted £44.39 each for a disc, and £47.34 for a set of pads.
I checked Euro Car PArts as I have a 30% code for them but I'm lost on which discs and pads to select, they have several all by the same manufacturer but the cost varies. What are the differences?
I opted for these as the pads:
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2007/p/car-parts/brakes/brake-friction/brake-pad/?101441178&1&5eb67050c8bcdf92e274212bdc96b49f0addbfa2&000036
and these for the Discs:
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2007/p/car-parts/brakes/brake-friction/brake-disc/?104441518&1&f8c089b3b927e176926e4777e0841d7da13b7633&000027
What have other people done?
Offline Baz300
Re: Rear Discs & Pads
« Reply #1 on: October 11, 2012, 05:48:28 pm »
I just bought a set of dimpled and grooved discs with mintex pads from mtech
Came in at £80 deliverd
If you are doing them yourself the caliper carrier is a nightmare to remove as space is very limited.
You need a 14mm splined bit (triple square) to remove the carrier, I only had a long one which made access even worse so I would advise a short one
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #2 on: October 11, 2012, 05:52:40 pm »
Have you thought of asking a garage to fit them? You'll need a spiral caliper wind back tool as well. I got VW discs and pads fitted parts and labour for £170 at an independent specialist yesterday. £170. :-)
Offline woky
« Reply #3 on: October 11, 2012, 06:11:59 pm »
i,ve got pagid pads front and rear on my gti, they were on the car when i bought it. they are good.
Offline AnSGTI
« Reply #4 on: January 24, 2013, 04:16:30 pm »
I see from searching the forum most people avoid ECP brakes as they're mostly made in China - is there anywhere where I can get OEM (or as close to OEM) parts from ata good price?
My local TPS will only sell to me at the same price the parts dept will at VW
Offline samdem
« Reply #5 on: January 24, 2013, 04:19:22 pm »
Hey i have to order pads tomorrow too from euro, i know theyre doing 20% offline. where did you get the 30% one from?
Offline AnSGTI
« Reply #6 on: January 24, 2013, 05:40:09 pm »
PAGID30
This is the problem, if you do a search in here even the most expensive parts from ECP aren't rated as good as OEM, in fact most recommend staying clear. The 30% off makes me wonder if I will ever notice, sure I give my car the beans but it's not modified nor does it ever get tracked.
Can I ask what pads you're going for?
« Last Edit: January 24, 2013, 05:41:57 pm by AnSGTI »
Offline samdem
« Reply #7 on: January 24, 2013, 05:50:27 pm »
TBH mate im just going to get the pagid ones, i havnt got uprated brakes or performance mods yet so i dont really see the point.. sure itd be nice to have awesome responsive brakes but tbh ive never driven with any other brakes than standard and they do the job fine for me.
Cheers for the code to man!
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #8 on: January 24, 2013, 05:53:38 pm »
I put a set of rear PAGID pads in recently, cheapo ones from ECP and they don't seem any worse than standard... I'm Stage 1.  The Fronts do so much more of the work, it's worth investing in them imho.
Offline samdem
« Reply #9 on: January 24, 2013, 05:57:27 pm »
Sorry to butt in on your post i hope you dont mind.
There are two sets of pagid pads for the front, some for £30 and some for £40.. any difference??
Offline GTI Leeds
« Reply #10 on: January 24, 2013, 06:21:33 pm »
I've got Pagid all round on mine and cant fault them... Always use them when doing jobs for family/friends etc and nobody has ever had a issue
Offline AnSGTI
« Reply #11 on: January 24, 2013, 06:24:10 pm »
Are these supplied from ECP? People say the ones that come from ECP aren't as good quality.
I also came across these:
http://www.mtecbrakes.co.uk/index.php?main_page=product_info&cPath=7_36_69&products_id=18711
« Last Edit: January 24, 2013, 06:30:32 pm by AnSGTI »
Offline camfollower
  • -Receive: 31
« Reply #12 on: January 24, 2013, 06:39:11 pm »
Not sure I'd go with them for the front tbh, but rears should be cool.  My experience of the GTI is that it's nearly always the most expensive pad / disc that's advertised that's the correct fit... LOL>
I was levelling the pressure on my tyres today and noticed my front discs are quite lipped with about 3mm of pad... think I'll be looking at something soon - BBKs are too expensive for me, but wouldn't mind some Tarox discs and pads; time to hammer Google search :laugh:
Offline SteveTDCi
« Reply #13 on: January 24, 2013, 06:50:09 pm »
What are the mtec brakes like ?
Offline camfollower
  • -Receive: 31
« Reply #14 on: January 25, 2013, 07:13:42 pm »
No idea mate - I'd love some drilled / grooved brakes mainly for the aesthetics, but have heard most of the cheapish materials (other than the top end Porsche type stuff) are simply going to crack; not sure how much of that is true...?
