Author Topic: Will I need to change Can Bus?  (Read 1354 times)
Offline Moz
« on: October 12, 2012, 03:44:22 pm »
Hey guys, I'm very close to buying a RNS 510 Version B (V8 maps / 3800SW) and want to also buy the BT module for it. I need to know if I'll need a new can bus for this?
Do I have to check my existing one? Any idea how I do this?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Will I need to change Can Bus?
« Reply #1 on: October 12, 2012, 03:47:02 pm »
3800 requires new type gateway
what is year is your car?
Cluster and Key coding
Location Great Yarmouth
Offline Moz
« Reply #2 on: October 12, 2012, 04:03:15 pm »
Hi Eddie, it's a 2005, date of first registration in the UK was 01/11/2005.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: October 12, 2012, 04:07:07 pm »
the answer is you will need to change it
i offer uncoded, pre-coded
Offline Moz
« Reply #4 on: October 12, 2012, 04:11:31 pm »
Hi Eddie, thanks for the quick response.
I'm a very much novice in this, and looking to buy this http://www.mk5golfgti.co.uk/forum/index.php/topic,54944.0.html
Would I need a uncoded or precoded gateway?
How much are they from you please? And also can you point me into the direction of getting a Bluetooth module to install at the same time?
« Reply #5 on: October 12, 2012, 04:22:42 pm »
If you don't have access to vcds then it's easiest/best to get Ed to precode it for you.
Offline Moz
« Reply #6 on: October 12, 2012, 04:25:34 pm »
Thank you, that will be the option I guess, as I can get the RNS fitted with GPS etc at a local car audio place.
« Reply #7 on: October 12, 2012, 04:34:56 pm »
Do you have the factory sound pack option as if you do you'll need to get the sat nav coded using vcds.
Offline Moz
« Reply #8 on: October 12, 2012, 04:37:29 pm »
I believe so, it's the standard sound system with the vehicle, it doesn't appear to have been upgraded or anything.
This is beginning to become an expensive addition!
« Reply #9 on: October 12, 2012, 04:52:40 pm »
Not really as I'm pretty sure if something needs coding then a helpful local member with a vcds cable will see you right.
Offline Moz
« Reply #10 on: October 12, 2012, 05:27:39 pm »
No doubt, I meant for the unit and the canbus and BT itself!
Especially just after Xenons.
