Author Topic: Fool the Light Sensor  (Read 7880 times)
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
Re: Fool the Light Sensor
« Reply #15 on: October 12, 2012, 09:04:05 pm »
Pretty sure the lights do go off when the ignition is not on even with the light switch turned to the 'on' position.
They do, I have mine on all the time, and they go off when you lock the car and it times out.
X3 That's definetely right. The lights will not stay on when you lock the car. Just leave your lights in the on position and forget about it, nothing to worry about.
Offline f1fan
« Reply #16 on: October 12, 2012, 09:09:41 pm »
I keep mine on the "On" position constantly. Where you said you don't want a flat battery, they stay on as Coming Home Lights for 30seconds±. Try it and see.
Must go try it, thanks.  Either I didn't wait long enough or because my car is a German spec not UK spec it's different.
Black 2008 GTi, InPro smoked door mirror indicators, genuine Autohaus Wolfsburg plate holders, uk legal pressed metal plates, LED number plate lights, MTEC super white headlights & side lights, LED internal lights, Polo stubby aerial, Kenwood DDX4023BT head unit & Enfig surround.
scottm72
« Reply #17 on: October 12, 2012, 09:11:00 pm »
get another volvo, ill second that  :happy2:
btw drl's are not just cosmetic they are a very good visibility indicator if you get the right ones, i have just ordered a set as yes i want the cosmetic upgrade but also to be seen as they are a lot better than side lights
£159
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #18 on: October 12, 2012, 09:12:11 pm »
If you have highline, you can change on how long they stay on for!
Offline f1fan
« Reply #19 on: October 12, 2012, 09:15:41 pm »
I don't have highline  :-( I wish I did as I like to have automatic locking doors.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #20 on: October 12, 2012, 09:17:29 pm »
You may be able to change it if someone has vcds
scottm72
« Reply #21 on: October 12, 2012, 09:17:43 pm »
i just tried that and didnt work,,, i put the lights to the full on pos and nothing, locked the car and also nothing ???
if i leave the lights on the auto pos and unlock the car the headlights stay on for 10 seconds only and when i lock it no lights again ?
wish i could make them stay on longer and also stay on for maybe 20 seconds once i lock the car,,, i do not have highline unfortunatelly so dont think i can ammend them unless anyone knows how
Offline f1fan
« Reply #22 on: October 12, 2012, 09:23:14 pm »
Bummer, so if that doesn't work, am I back to trying to cover, fool, shortcut the light sensor?
Anyone know where the sensor is?  Is it built into the rear view mirror mount?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #23 on: October 12, 2012, 09:27:18 pm »
I think its built into the windscreen, near to the rear view mirror, just below it
Offline Adam_
« Reply #24 on: October 12, 2012, 10:04:52 pm »
Did you put the ignition on when you tried it?
Just quickly videoed mine.
Offline Moz
« Reply #25 on: October 12, 2012, 10:28:03 pm »
Scrapped Drls and went or yellow tint fogs
scottm72
« Reply #26 on: October 12, 2012, 10:44:54 pm »
yellow tint fogs,,, as far as i can see the fogs dont do very much,,, surely drl's would be much more penetrating to see,,, i mean i know they are but what is your thought on that
scottm72
« Reply #27 on: October 12, 2012, 10:51:24 pm »
[/quote]silly me, i tried it by starting and stopping the engine, first leaving the light in the auto position and then tried leaving it on the on position,,, each one gave me the same,,, 10 seconds
would like more time, maybe 30 seconds.
so to clarify my lights go on for 10 seconds when i remote open the car and agin for ten seconds when i turn of the engine ????
how can i get this extended without highline controls
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #28 on: October 12, 2012, 10:52:18 pm »
^^^ VCDS probably.
Offline SI-R32
  • -Receive: 125
« Reply #29 on: October 13, 2012, 08:57:37 am »
if you tick  byte 0 bit 3 with VCDS in the pic below in the CECM your headlights will work exactly as you want, just like a Volvo
