Author Topic: RNS510 question  (Read 2443 times)
Offline ArildStavrum
RNS510 question
« on: October 13, 2012, 03:28:54 pm »
I'm on the verge of buying the RNS510 and have bought a CANBUS version M, my question is will this be ok and I won't be effected by the battery drain issue?
I have a 2006 gti.
  • -Receive: 291
Re: RNS510 question
« Reply #1 on: October 13, 2012, 06:15:57 pm »
It's Revision K and earlier so you're fine with whatever version. I have a 2007 ED30 with Revision L and never had drain issues.
Offline Ree
Re: RNS510 question
« Reply #2 on: October 13, 2012, 07:25:05 pm »
From what I know battery drain affects up to early 2007 models.
My car is a 56, however my RNS510 has a modified firmware which means I do not need an update canbus.
If you require further info speak to Nick on r32oc.com he is the RNS Guri there !
  • -Receive: 291
Re: RNS510 question
« Reply #3 on: October 13, 2012, 07:51:16 pm »
We also have RNS gurus on here like Eddie-NL. vwnavi.com and my-gti are useful resources.
Any canbus after K should be fine. If you definitely have M (which is odd since I have L in a 2007 - are you sure yours wasn't already upgraded at some point?), then you should have no issues with Canbus drain.
« Last Edit: October 13, 2012, 07:52:47 pm by stealthwolf »
Offline Little_Dave
Re: RNS510 question
« Reply #4 on: October 13, 2012, 08:29:41 pm »
Same here i'm running a modified firmware that Nick loaded for me to prevent battery drain and the need for an updated canbus  :happy2:
Dave
Re: RNS510 question
« Reply #5 on: October 13, 2012, 09:11:06 pm »
I'm using an "incompatible" version F without the issue of battery drain due to having a Polar FIS installed.
Re: RNS510 question
« Reply #6 on: October 14, 2012, 09:26:01 am »
thanks folks, i bought the CAN version 'M' from another member on here a while a go with the view of upgrading to the rns510 or the rcd510.
I've no idea what version of the CAN is currently in my car!
Offline golfman
  • -Given: 17
Re: RNS510 question
« Reply #7 on: October 14, 2012, 09:58:36 am »
Where are you based?
could help with fitting!!!
send me a Pm
scott :happy2:
Vag-com Hex+Can in scotland
I Hate Timewasters...
