Author Topic: Fitting Car Alarm  (Read 1722 times)
Offline f1fan
Fitting Car Alarm
« on: October 13, 2012, 10:22:40 pm »
My mk5 GTi doesn't have an alarm fitted. Can anyone give me any advice on how much a standard vw alarm would cost or a better non vw option?
Black 2008 GTi, InPro smoked door mirror indicators, genuine Autohaus Wolfsburg plate holders, uk legal pressed metal plates, LED number plate lights, MTEC super white headlights & side lights, LED internal lights, Polo stubby aerial, Kenwood DDX4023BT head unit & Enfig surround.
Re: Fitting Car Alarm
« Reply #1 on: October 13, 2012, 10:34:29 pm »
What, no alarm??
Was it an import?
Offline skard
  • -Receive: 245
« Reply #2 on: October 13, 2012, 10:38:50 pm »
Maybe your siren's died?
When you lock with the fob, then open drivers door with key blade (don't press buttons) and get in, do your indicators start to flash after ~15 seconds?
As above, if it's UK spec then surely it should have an alarm.
  • -Receive: 427
« Reply #3 on: October 13, 2012, 11:10:11 pm »
Maybe get someone to have a look through a diagnostics scan (VCDS) for you.
If you have some buttons at the base of the b pillar, you have an alarm, if no buttons, you just have an immobiliser. One of the buttons turn off the motion sensors and the other turns off the tow away protection, if you have these I assume you have an alarm. If no buttons, maybe an import.
Have you tested for an alarm? IIRC you lock the car with the fob, wait 30 seconds or so and unlock with the key and Roberts your dads brother, noise.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: October 13, 2012, 11:13:07 pm »
factory alarm can be added, but get a scan done first to see if you have one and it's not working
Cluster and Key coding
Location Great Yarmouth
Offline swiftlupogti
« Reply #5 on: October 14, 2012, 10:21:37 am »
Seen you can get a canbus aftermarket alarm which will work off the existing key for around £250 and thatcham approved
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: October 14, 2012, 10:26:05 am »
The main cost of the factory alarm would be the siren and interior motion sensors
although this is a cheap option
Offline f1fan
« Reply #7 on: October 14, 2012, 08:44:19 pm »
What, no alarm??
Was it an import?
Yes it was imported to the UK direct from the factory.  I don't think it has an alarm, no button to disable ultrasonic sensors.  To be honest the vw dealer I bought it from didnt really know much about the car, had to find a lot out for myself.
Offline f1fan
« Reply #8 on: October 14, 2012, 08:49:11 pm »
Do you think it's better to get a VW alarm or aftermarket?
Part of me wonders if an alarm is worth having, no one ever pays attention to them!
