Author Topic: Rear Wiper...  (Read 863 times)
Offline captaindugg
Rear Wiper...
« on: October 15, 2012, 11:09:47 am »
Hi guys
I've had a good old search and read but can't find all my answers!  My rear wiper has decided to give it up...if I push back on it you can here it pushing water to the back, 25% comes out of the jet on the outside, the other 75% goes inside the car, and ends up in with the spare tyre!  The actual wiper arm does not move at all though.
I checked all fuses and all seem to be ok and not blown.
So I have removed the panel.  Then I tried to spray water and well after that everything was soaked! lol...it did look at tho it is coming out of the actual sealed unit piece.  Any ideas?  Or if the arm doesn't move it is just a case of a whole new wiper/motor arm unit?
Have many of you removed it entirely, shall I just take it off and plug it or replace with a new motor....hmmm....
Thanks for any help!
Offline brough74
Re: Rear Wiper...
« Reply #1 on: October 15, 2012, 11:24:30 am »
You will need a new motor unit, i had to replace mine a bit ago.
The washer fluid goes through the motor arm and over time it seizes and then shears off.
Probably water has got in your motor and shorted it.
You also might need a new wiper arm as my old one was solid, but you can buy a wiper puller which might help. Its an easy job really once you get everything apart.
« Last Edit: October 15, 2012, 11:29:06 am by brough74 »
PEARL DIAMOND BLACK 3dr GTI
HEATED LEATHER,MULTI FUNCTION WHEEL,
18” MONZA ALLOYS, XENON HEADLIGHTS, FLAT TYRE INDICATOR
LUX PACK AND WINTER PACK
SHARAN AERIAL, GTI TAX DISC HOLDER, R32 REAR LIGHTS
VW RACING FRONT SPOILER
