Author Topic: Will this harness work?  (Read 1120 times)
Offline CMB
« on: October 15, 2012, 06:54:41 pm »
My RCD300 has packed in and just glows blue with no writing on the screen and no sound being produced so I've decided to put my old single DIN stereo, just ordered the facia adapter from the VW dealer and just looking into the wiring harnesses, don't want to spend a fortune. Would this work?
http://www.caraudiodirect.co.uk/con-ct20vw01-ct20vw01-harness-adapter-vw-passatgolftouaregtouran.html
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Will this harness work?
« Reply #1 on: October 15, 2012, 06:57:27 pm »
just buy another rcd300 they are cheap
Cluster and Key coding
Location Great Yarmouth
Offline CMB
« Reply #2 on: October 15, 2012, 07:08:51 pm »
Yeah but i want some better sound anyway, need a sub in that thing was crap. if that harness will work I've got everything else sorted so will be cheaper than buying a new RCD300 anyway.
Offline Gazza747
« Reply #3 on: October 15, 2012, 07:14:15 pm »
You will need a radio adaptor, these in my experience never fully replicate the original radio reception.
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Offline CMB
« Reply #4 on: October 15, 2012, 07:25:55 pm »
Yeah I'm not bothered about the radio I never listen to it, just want to know if that harness would work? Don't have steering wheel controls or anything like that and not bothered about any of the dimming or volume increasing when you go faster stuff. Aslong as it will play I'm a happy man.
Offline Gazza747
« Reply #5 on: October 15, 2012, 07:29:32 pm »
Also you will need to connect the power to a switched live. The adaptor seems to be right.
Offline Squeeguk
« Reply #6 on: October 15, 2012, 07:44:55 pm »
As above, you should be ok with the adapter in the link. Worst comes to worst you will have to run a switched live from the fuse box as mentioned already. I would try the adapter as it comes and see how you get on before running any additional wires. The Connects 2 adapter should be plug and play.
