Author Topic: W/Meth, fitted with pics  (Read 5495 times)
Offline gazon69
« on: October 15, 2012, 07:53:11 pm »
Had a little something going on over the weekend, in the way of a Devils Own w/m kit. I took my time fitting it as i have been tooing and froing here and there.
I started by getting all of my wiring ready to plumb in.
I had to strip out the battery and the glove box to get the wires through the bulkhead, (total barstewards of a job)
I hid all of the wiring under the carpet and fixed the relay underneath the passenger footwell.
Next i took a 12v ignition live from the cigarette lighter. I just tapped into the wire for this.
All of the methanol feed line was next, that had to go from the pump in the boot, through the bulkhead then into the inlet pipe.
To mount the pump and tank i got a sheet of mdf and cut them out just a little bit bigger than the tank and pump and mounted it behind the carpet on the wheel arch and for the pump i bonded it to the boot floor. I bonded them in because i didn't fancy drilling the bodywork.
I then ran the boost line, again through the bulkhead. I mounted the boost controller in the flipdown drawer under the drivers side dash. Makes for easy adjustment.
I then inserted the jet into the inlet pipe and connected up the meth pipe.
After connecting up all of the wiring to appropriate place I fired up the car to check all was working.
Gutted. No power to the pump. Checked everything down to the last wire. All was present and correct. Or so i thought.
Shot down to statllers for a bit of know how and low and behold i had tapped into the wrong wire for the 12v ignition live.  :confused: Switched it around and bingo, fired up.
Shot back home and put everything back together.
Here's the finished article.
Not had time to get any methanol theough it yet.
Tried a bit of water and have to say there is some noticable difference.
Car feels a little stronger now.
Can't wait untill tomorrow now to get some methanol mix in. Going to get it dyno'd also to see what the differences are with and without.
Need my new clutch now. :wink:
Thanks for looking, Gaz
« Last Edit: October 15, 2012, 07:56:35 pm by gazon69 »
Offline Scrubadub
  • Soon to be "bagged"
Re: W/Meth, fitted with pics
« Reply #1 on: October 15, 2012, 08:08:39 pm »
It's a good kit, I used to run 1 on my corrado g60. Any better pics of where and how you mounted nozzle?
Fun bags
« Reply #2 on: October 15, 2012, 08:12:42 pm »
Good effort  :happy2:
Offline gazon69
« Reply #3 on: October 15, 2012, 08:16:27 pm »
Offline gazon69
« Reply #4 on: October 15, 2012, 08:18:22 pm »
not really, hard to get a camera down there. I bought a bsh/revo inlet pipe. There is a mounting point on it especially for meth kits. I will try and get a better pic tomorrow. :happy2:
Offline cupra_k1
« Reply #5 on: October 15, 2012, 08:20:58 pm »
Great stuff mate. What size nozzle are you running?
Offline gazon69
« Reply #6 on: October 15, 2012, 08:29:46 pm »
no 2 nozzle at the moment. Dont officially know the size dude. Haven't ran it properly yet so dont know what to expect. My cars running around 340 so any improvement on that and i'll be happy.
« Reply #7 on: October 15, 2012, 09:24:12 pm »
If you're still running standard rods, be prepared for one bending...   :scared:
Offline james
« Reply #8 on: October 16, 2012, 08:48:24 am »
rods will be fine, i have run 100% on my cdl no problems.
on the bwa i run 60/40 and that was fine also, just killed a piston ring.
i will show u pics of mine, you might want to move the pump
Offline gazon69
« Reply #9 on: October 16, 2012, 08:52:01 am »
why move the pump james?  :confused:
Offline james
« Reply #10 on: October 16, 2012, 09:10:22 am »
free up your boot,  i will take a pic now of mine now.  1 sec
Offline james
« Reply #11 on: October 16, 2012, 09:15:07 am »
can show you others.  how did you route to the engine?
Offline gazon69
« Reply #12 on: October 16, 2012, 09:16:21 am »
Tbh mate nothing really goes in my car boot. The missus does all the shopping. If i need to get anything bulky it goes in hers.  :happy2:
Offline james
« Reply #13 on: October 16, 2012, 09:23:45 am »
oh ok cool,  what engine you got?
what is your peak boost? and boost at redline?
Offline gazon69
« Reply #14 on: October 16, 2012, 09:55:26 am »
Got bwa in there matey. If it goes pop i'll prob just slot an ed30 lump in. Not done any testing what so ever yet mate as im at work. Should be done around 1ish so gonna head down to statllers and get it on the rollers. I'll post dyno up once done.  :happy2:
