Author Topic: W/Meth, fitted with pics  (Read 5492 times)
Re: W/Meth, fitted with pics
« Reply #15 on: October 16, 2012, 10:30:29 am »
James, the pump should really be below the bottle as it is gravity fed. If not it can cause pumping issues when the level drops and strain the pump. :smiley:
Offline gazon69
« Reply #16 on: October 16, 2012, 10:41:40 am »
Are you sure John? I could have sworn that it says it doesn't matter where the pump is placed in my instructions :confused:
« Reply #17 on: October 16, 2012, 11:20:15 am »
It would depend on the suction lift on the individual pump, surely?
Offline james
« Reply #18 on: October 16, 2012, 11:37:45 am »
my manual just said mate sure it is not above the tank,  never had any problems, it can empty the whole thing. :drinking:
« Reply #19 on: October 16, 2012, 02:40:21 pm »
Hmm, maybe I got a different set of instructions. If this is the case I'll probably do something similar on the R :happy2:
Offline cupra_k1
« Reply #20 on: October 16, 2012, 03:18:38 pm »
Great stuff mate. What size nozzle are you running?
no 2 nozzle at the moment. Dont officially know the size dude. Haven't ran it properly yet so dont know what to expect. My cars running around 340 so any improvement on that and i'll be happy.
What Map are you running mate? You Should see a healthy gain when set up correctly on Meth. You may benefit by increasing your nozzle size too. I'm currently running a dual nozzle set up (DO2 Pre TB / DO1 Post TB) and Steve Jnr recommended me upping my nozzle sizes a little.
Offline cupra_k1
« Reply #21 on: October 16, 2012, 03:22:06 pm »
As John said the Devil's Own instructions state that the pump should be mounted below and as close to the tank as possible, however how critical this is I don't know.
Just out of curiousity, is anybody running WMI on a KO4 motor with a Rev G (diaphram) DV fitted?
Offline james
« Reply #22 on: October 16, 2012, 04:28:13 pm »
Yea I am
Offline cupra_k1
« Reply #23 on: October 16, 2012, 05:40:52 pm »
Yea I am
Where's your nozzle located bud? Reason I ask is because I have had two Rev G DV's fail on me since running WMI. I took them appart and they were soaking wet. The Rev D seems to be holding up ok so far although I don't know how long it will last.
Offline james
« Reply #24 on: October 16, 2012, 06:43:54 pm »
Tb pipe, your running to much meth. What psi u injecting at?
If it is soaked ur tb will die also soon
Also what mix u running?
Offline gazon69
« Reply #25 on: October 16, 2012, 07:11:12 pm »
my bad, the instructions do state that the pump should be below and as close to the tank as possible. James, if you were to rotate your pump 180 degrees that would put the feed lines below your tank and suffice i would have thought. Though yours is a different product so you may be ok.  :happy2:
Offline cupra_k1
« Reply #26 on: October 16, 2012, 07:21:15 pm »
The thing is i'm only running a 126ml/min nozzle pre TB/DV which is located right at the bottom of the Throttle Body Pipe, which as far as i'm aware is far from excessive. The pump is set at 200psi from memory and i'm running a 50/50 mix.
Offline cupra_k1
« Reply #27 on: October 16, 2012, 07:22:24 pm »
How did you get on today mate? Did you manage to run it on Meth on the rollers?
Offline gazon69
« Reply #28 on: October 16, 2012, 08:08:43 pm »
no mate, my wifes nan is in hospital on her death bed (god bless her) so been running about after the kids all afternoon. Gonna try tomorrow depending on what steves got on. :happy2:
Offline cupra_k1
« Reply #29 on: October 16, 2012, 08:22:08 pm »
Sorry to hear that mate, fingers crossed Steve can squeeze you in at some point tomorrow!  :happy2:
