Author Topic: R32 Rear Bumper Question  (Read 3651 times)
Offline Wolf Burger
« on: October 19, 2012, 10:20:01 pm »
Hi All!
Question regarding the lower section of the OEM R32 rear bumper.
This as we know consists of two sections.
1.) The lower actual bumper that is colour coded and holds the two red reflectors
2.) Black plastic central exhaust section with central cut out for twin exhausts.
Is it possible to fit the above to a standard GTI but buy a black plastic exhaust section (Item 2.) for the standard exhaust outlet.
I see Red Robin has done something similar but using twin double exhausts.
I love the R32 rear but would prefer to keep the standard side outlet. Any pics of this would be great if available
Thanks  Mr W.Burger  :drinking:
Golf Mk6R 2011- Rising Blue- Manual-
Modifications-
E-Tuners 361 BHP - 350lbs
Revo Intake
Bilstein B16 & H&R ARB's
Team Dynamics 1.3
18Z Porsche BBK
RNS510 with Focal Speaker upgrade
MK6 Recaro Heated Buckets
Cruise Control
Highline Reverse Camera
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: R32 Rear Bumper Question
« Reply #1 on: October 19, 2012, 10:23:07 pm »
Yep you can get a single side section - cant remember where from but im sure someone will be able to tell you :happy2:
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #2 on: October 19, 2012, 10:29:38 pm »
Srs-tec.de do the single exit trim :happy2:
Offline Matto
  • -Receive: 116
« Reply #3 on: October 19, 2012, 10:35:40 pm »
Have a look here for the different options. http://www.mk5golfgti.co.uk/forum/index.php/topic,49394.0.html
Offline Wolf Burger
« Reply #4 on: October 19, 2012, 11:09:12 pm »
Thanks yet again guys!!!!!!  :notworthy:
This is just the sort of thing I am thinking.
I could keep the standard exhaust and buy a side outlet trim (Could then change to a central exhaust if I wanted later)
Do you just adapt the rear exhaust to go with no rear exhaust outlet??
Modifications-
Revo Intake
Team Dynamics 1.3
18Z Porsche BBK
Cruise Control
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #5 on: October 20, 2012, 06:58:46 am »
I believe to get the "clean look" like below you use a back box off a TDi Golf as their tips curve downwards
Here's a link to SRS's R32 inserts
http://srs-tec.de/cars/VW/Golf-V/Rear-diffuser:::12_58_86.html
And to Osir's:
http://www.osirusa.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=VR32EB
Also to have any exhaust configuration other than the R32 central twin pipes you would need to adapt the rear bumper. Really easy to do, basically the bit circled in the pic below needs cutting off as other inserts will not fit and the standard exhaust or quads rub against it aswell
I've gone the same route as Robin with quads but I've got the matt Osir insert where as Robin's is gloss. I got mine 2nd hand on here for £100 but if you want new they are stupid money where as srs are only 169euro and quality is apparently good.
Here's a cheeky pic of mine:
beleive it or not thats the same colour as the 1st pic
Offline Superted74
« Reply #6 on: October 20, 2012, 09:17:15 am »
Now that's how the Gti should have looked from standard!
