Author Topic: Hesitation/Stutter under load in high gear  (Read 4555 times)
Offline john a
    • The Veneers Cover Band
« on: October 20, 2012, 09:15:58 am »
There's a slightly similar thread a bit further down the page but my car is not exhibiting exactly the same symptoms.
It's a 2.0 TFSI with an APR stage 1 map, under load in 5th and 6th (at fairly high speed) the car seems to momentarily hesitate, almost like a cough I guess. I've done a bit of logging (not recently) which showed low fuel pressure at the rail but didn't log the two pumps separately. Symptoms have also been present with and without the map.
There is also a slightly rough idle too, I've changed PCV and plugs (latter about 10k miles ago) and other than changing all the fuel delivery parts, don't really know what else to do. Thoughts?
Offline capster
Re: Hesitation/Stutter under load in high gear
« Reply #1 on: November 04, 2012, 01:51:06 pm »
Coilpacks  :happy2:
« Reply #2 on: November 04, 2012, 03:18:51 pm »
Coilpacks  :happy2:
Agreed, live log blocks 015 and 016 with vcds for misfires.
« Reply #3 on: November 04, 2012, 03:20:48 pm »
Have you visually checked your cam follower?
Offline john a
« Reply #4 on: November 04, 2012, 04:41:10 pm »
I replaced the cam follower a few months back, some of the coating had worn off the top but it was in otherwise reasonable shape. Symptoms have been present prior to the follower being replaced.
I have had one instance of a misfire on cylinder 3, I haven't yet checked the coil or the plug, but I have also been unable to repeat the symptoms, although I haven't driven the car especially hard.
As the fault codes I was logging were to do with fuel rail pressure, could a misfire cause that (and not show a fault for a misfire)? I have only had the engine light flash once after the misfire, not after any other occasion.
« Reply #5 on: November 04, 2012, 11:40:46 pm »
Can you remember the exact fault code as it could well be your low fuel pressure sensor being faulty...
Offline john a
« Reply #6 on: November 05, 2012, 09:59:56 am »
000135 - Fuel Rail/System Pressure
   P0087 - 002 - Too Low - Intermittent
Having changed the follower recently, either the sensor is knackered or the pump itself presumably?
« Reply #7 on: November 05, 2012, 10:57:11 am »
I agree with you if your cam follower and cam lobe surface were ok. It's cheaper to change the sensor so IMO try that first though a new one is about £48
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #8 on: November 05, 2012, 10:08:07 pm »
Sounds similar to something I had a while back, ended up having the tumble flap reset. Here is my previous thread if it helps
http://www.mk5golfgti.co.uk/forum/index.php/topic,35518.0.html
Offline jamiep91
« Reply #9 on: November 11, 2012, 12:28:35 am »
I have exactly the same problem but in 3rd 4th 5th and 6th it does it and the speed hardly increases ? Have you got
To the bottom of your problem yet
Offline Alex156
« Reply #10 on: December 02, 2012, 03:06:47 pm »
Any progress with this, I have a similar issue!
Offline jamiep91
« Reply #11 on: December 02, 2012, 07:21:34 pm »
Mines a misfire in cylinder 2
