Author Topic: After a bit of information on where I stand with an issue  (Read 1760 times)
Offline snapey
« on: June 16, 2009, 10:20:04 pm »
Evening chaps,
Basically I'm after a bit of help and opinions on where I would stand with regards to an issue with my car.
Basically about 3500 miles ago the clutch and flywheel went on my car, these were all replaced under warranty. However ever since its been fitted there seem to be quite a few issues which have arisen. Basically the first issue as this whining:
This then subsided after about 800 miles after numerous visits do the dealer to get it to show up and it being intermittent.
The car since then develops a quite knocking when idling in neutral, the dealer heard this and the mechanic was quick to dismiss it and say its down to backlash from the gears. When questioned how this was possible when no gears are selected, he couldn't come up with an answer. This is still doing it at the minute.
Today on the way to work, without driving hard etc, the faint smell of clutch started to brew with the windows down.
Now how would I stand with all these issues, because even though there only small I'm almost confident its down to the way they have fitted the clutch or flywheel because they have only ever started when its been fitted.
If you could shed some light on it for me it'd be very much appreciated because I don't want to go in all guns blazing.
Luke
If you have to ask why, you'll never understand.
Offline TomB
Re: After a bit of information on where I stand with an issue
« Reply #1 on: June 16, 2009, 11:11:10 pm »
I'd take it up with VW Customer Services personally.
Explain the situation and they should be able to advise you of the best action to take.  Other manufacturers I've worked for have phoned the dealer direct and got them to do the work, so VW should do the same.
If they acknowledged there was a fault with the clutch and flywheel, its not unreasonable to expect other parts in the transmission to get damaged, either by the faulty part or in the process of fitting of the replacement parts.
The other option is to take it to another dealer, their service manager might be more sympathetic.
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
Offline TomB
« Reply #2 on: June 16, 2009, 11:13:58 pm »
Oh and the noise on startup is either a faulty starter motor or a mistightened belt.
Does the sound go away after a few seconds?  If so, definately starter and it only supports your gearbox related woes as they bolt into the gearbox!
Tom
Offline snapey
« Reply #3 on: June 16, 2009, 11:21:03 pm »
The whining stopped about 3 months ago, its now been replaced by this constant rattle that you have to listen out for from inside the car with just the engine running and it sounds as though it's coming from the gearbox area when the bonnet is up.
All sounds a bit dodgey from my point of view.
Offline TomB
« Reply #4 on: June 17, 2009, 12:17:00 am »
It certainly does, are you going to call customer services?
Tom
Offline snapey
« Reply #5 on: June 17, 2009, 12:27:10 am »
Yeah I'll give them a call tomorrow to raise the concern with them and have it recorded on the system and see what they recommend I should do.
Cheers for the help dude  :happy2:
Offline TomB
« Reply #6 on: June 17, 2009, 01:12:23 am »
If you can remember dates and names of people, that will really help you out.
No worries - all the best!
Tom
Offline snapey
« Reply #7 on: June 17, 2009, 11:12:42 pm »
basically I rang VW this morning to raise the concern with them that the clutch had not been fitted right, after I have been to the dealer about 3/4 times before to try to get the issue sorted customer care said something should have been done about it right from the start.
The car is going back in on Friday to have an aircon issue sorted, so customer care are ringing the dealer to inform them that they need to sort it out. They agree it didn't sound right and will make sure full technical reports from the first fitting and an inspection that WILL take place on the car are sent to their technical guys at MK. So hopefully should get it sorted.
I showed that video to the mechanics and the service guys there and they said well unless we hear it in person there's nothing we can do..... load of BS, so this video will be going down again for them to tell me that it wasn't a direct result of them bodging the clutch.
There's also no indication from the first warranty sheet that and investigation work had been carried out either side of the friction plates. I.e. crank and gearbox for heat damage, FOD etc etc. and since the clutch went pop 2nd and 3rd have been terribly notchy on occasions, possibly one in two changes.
Overall hopefully it'll get sorted and I can really start to enjoy driving the car right without getting angry with a sh*t gear change.
Many thanks, Luke
Offline TomB
« Reply #8 on: June 17, 2009, 11:27:17 pm »
Excellent news, I love it when CS come down heavy on the dealer!
I'm glad its getting sorted now, let us know the outcome!
Tom
