Author Topic: RCD510 and Bluetooth  (Read 972 times)
Offline oo1005
« on: October 22, 2012, 03:23:37 pm »
I'm on the verge of buying an RCD510, but before I do is there somewhere I can get a run down of whats needed for bluetooth? Are all the units the same its just a case of having a BT module? And if so is there a specific module thats needed?
Thanks!
'07 GTi 5dr Black, Monza IIs, Xenon
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: RCD510 and Bluetooth
« Reply #1 on: October 22, 2012, 03:44:49 pm »
Some RCD510 have an issue with some of the newer phone kits, so best to check
7P6 and 5K0 are the cheapest option
729b is the most expnsive
I can supply 5K0, 7P6 and 729B
and you can also use the Fiscon
Cluster and Key coding
Location Great Yarmouth
Offline oo1005
« Reply #2 on: October 22, 2012, 03:47:25 pm »
Thanks Eddie - could you give me an idea on the price range? It will be for an iPhone4S (one day an iPhone 5..)
How can I check which version the RCD is?
Thanks again
Offline nathangallo
« Reply #3 on: November 12, 2012, 07:58:22 pm »
Hi fella I'm just enquiring the same thing at the moment. What was the outcome?
Offline oo1005
« Reply #4 on: November 13, 2012, 09:09:27 am »
I gave up in the end as it worked out cheaper for me to get an aftermarket unit..
Offline Slip
« Reply #5 on: November 13, 2012, 09:14:24 am »
I'm thinking the same, I've already got a Parrot kit but the integrated would probably give a cleaner look, plus I reckon I can get some back from the Parrot... it's just whether the integrated kit works with the iphone 4s / 5..
Did you find anything about the compatibilty?
Offline oo1005
« Reply #6 on: November 13, 2012, 09:23:11 am »
For oem only whats above here..
