Author Topic: FW 4020,POI on sd card problems  (Read 1365 times)
Offline gtlee
« on: October 23, 2012, 12:21:28 pm »
I've updated my FW to 4020 and with V9 maps on my RNS510,the problem is that the speedcams are only limited to 2 types so I tried to more from another database.
Used Poinspector to assemble the speedcam locations and saved to sd card.
Inserted the sd card into RNS and nothing happens,the SD card & favourite POI were greyed out,so proceeded to search for the personal POI folder which I found and imported the data.
All went well but with the speedcam icons ticked on in the map detail section and rebooted the speedcam icons will not display at all?
Any ideas guys? :notworthy:
Update; Went away for a few hours started the Rns up again still no icons,deleted them and tried one speedcam icon at a time and surprise it showed up on the map.
Proceeded to add the others and happy to say all is working as it should,problem is what was the problem then.
« Last Edit: October 23, 2012, 01:54:13 pm by gtlee »
Golf V 5DR DSG GT Sport,,Xenons,Full leather,18'Charlestons,Lux pack,storage pack,folding mirrors,front armrest, retrofited--mk5 gti  grilles,fog lamps grilles,GTi rear bumper,coloured coded sideskirts, VIM RNS-510 C,MK6 MFSW with paddles,GTi DSG gear lever,Cruise control,Highline.Rain sensor with window auto closure,TPMS.7P6 Bluetooth.
Mods to come: RVC, and.................
Offline MarkMarked
Re: FW 4020,POI on sd card problems
« Reply #1 on: October 23, 2012, 08:11:02 pm »
There is a limit to the number of personal POIs that you can display, if you try to select too many, you lose the lot
Offline gtlee
« Reply #2 on: October 23, 2012, 10:31:48 pm »
Strange that because I always use the same format speedcamera locations and before this firmware upgrade there has been no issues.
Could it be that the poi's that were loaded with the V9 maps crashed with the poi's  I used?
