Author Topic: Weird one to help with....  (Read 1281 times)
Offline Timi8888
« on: October 24, 2012, 10:38:56 am »
Basically...
Every now and then my battery will cut off. Sometimes I will press the unlock button on key fob, but battery will seem like it's dead. I have to unlock the car manually and then pop the bonnet, and move the battery around a little, and it the power will be back on but clock and trip will have reset to 0.
It sometimes happens when I start the car too. So when I am about to turn ignition key, the lights come on for half a second, then it all cuts out, again like the battery is dead. I can get the car going again if I slam the door shut or pop the bonnet and move the battery around.
A couple of times as soon as I turn off the car, before I pull the key out, all the power cuts off again.
It has never cut off while driving or anything like that.
Can anybody help?
Sig to big.
Re: Weird one to help with....
« Reply #1 on: October 24, 2012, 12:35:12 pm »
Sounds like loose earth. Have you checked your battery connections, they might be a bit loose.  :happy2:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #2 on: October 24, 2012, 12:40:47 pm »
x2 ^^^
Sounds like something is not connected correctly...
Good luck with getting it sorted  :happy2:
Silver is the way !
Offline Timi8888
« Reply #3 on: October 24, 2012, 03:29:58 pm »
If it were a loose connection, say I was driving, would it not randomly cut off then?
Sig to big.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: October 24, 2012, 03:40:10 pm »
no because the alternator is providing the juice
Cluster and Key coding
Location Great Yarmouth
Offline Timi8888
« Reply #5 on: October 24, 2012, 03:45:46 pm »
Okay I see. Well it seems like it is something simple then and puts my mind at rest, until I sort the problem that is. By connections do you mean just the ones at the point of the battery?
Sig to big.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: October 24, 2012, 04:12:12 pm »
The eart is fixed to the car body, so check that too
