Author Topic: Key problem..?  (Read 694 times)
Offline oo1005
Key problem..?
« on: October 25, 2012, 10:37:21 am »
One of the keys is not working as a remote - its not the batteries as I've swapped them, the key works fine as a key in so much as I can lock/unlock and drive but none of the remote functions work - the LED is flashing as expected on a key press but it seems the car is just not seeing the commands... I've tried re-synchronising the key as per the manual but that made no difference..
Has anybody else seen this?
Phil
'07 GTi 5dr Black, Monza IIs, Xenon
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Key problem..?
« Reply #1 on: October 25, 2012, 10:58:28 am »
you need someone with vag com to try and recode the remote, if that fails a new remote
Cluster and Key coding
Location Great Yarmouth
Offline oo1005
Re: Key problem..?
« Reply #2 on: October 25, 2012, 11:00:03 am »
Cool, my dad has a VAGCOM which he uses for his Touareg which he's sending to me. Is it an easy procedure to do?
RayD
Re: Key problem..?
« Reply #3 on: October 25, 2012, 09:10:20 pm »
On a similar subject ...
I have two keys for my Mk 5 1.4 TSI
One of them opens all the doors on a single press ... and the other always needs pressing at least twice to do the same thing ... even then it won't be certain to have unlocked the boot.
I had thought it was related to which key was in the ignition when the choice to open all the doors was made on the dash ... but I ruled that out by doing it twice ... once with each key.
Ray
