Author Topic: LED Door Warning Lights - Review  (Read 44268 times)
Offline andybon
Re: LED Door Warning Lights - Review
« Reply #30 on: December 25, 2012, 08:30:16 pm »
Great, Nice easy mod for a change :)
Do you have to search for the connectors or are they obvious?
How hard can it be?
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
« Reply #31 on: January 17, 2013, 01:16:27 pm »
just got those today!
The quality and packaging is great
Can't wait to have them fitted
Paul
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #32 on: January 21, 2013, 08:44:25 pm »
Looking at these for a 2 door. Are the approx £35 for the bulbs and the holders? Just a bit confused as you can add bulbs seperately too!  :ashamed:
  • -Receive: 427
« Reply #33 on: January 21, 2013, 09:15:06 pm »
Yeap, around that price for the light units, the LED bulbs and the mini door looms that are required.
Here you go, with the LED Hyper White Bulbs selected (if that's what your after), for a 2dr with mini looms £35.90 + £5.98 shipping).....
Click here
Just click on "View Cart" and your done!
« Last Edit: January 21, 2013, 09:16:46 pm by MC71 »
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #34 on: January 21, 2013, 09:32:25 pm »
Ahhhh, i added the bulbs seperately and then the holders with more bulbs in.
Cheers!
  • -Receive: 427
« Reply #35 on: January 21, 2013, 09:50:25 pm »
^^^^ you is welcome. No thanks required.  :happy2:
Offline blade4real2004
« Reply #36 on: January 26, 2013, 12:11:46 pm »
Does anyone know the wiring for these on each gen module for any of us looking to do this also how do you find out what module you got?
I got a 55 plate 3dr gt tdi
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #37 on: January 26, 2013, 12:28:07 pm »
You most likely have a gen 1 /2
I used this guide
http://www.my-gti.com/2158
Put the 12v pin into pin 1 and took the ground from the petrol cap switch from driver side and I think it was from the window control on passenger side
« Reply #38 on: January 27, 2013, 01:47:23 am »
Cheers for that can you pick up the module numbers with vcds or will I need to drop off the door panels?
Offline jimbob001
  • 2.0 GT TDI
    • Ma5da Racing
« Reply #39 on: January 27, 2013, 02:39:52 am »
Very good write up!!
How easy is it to upgrade from OEM to LED ones??
please can you add an install guide, I am sure there is one but can not find it!!   :sad1:
  • -Receive: 427
« Reply #40 on: January 27, 2013, 07:14:57 am »
^^^^ cheers!  :drinking:
The door card needs to come off first. Heres a written (with pics) guide and also a video guide on taking the door card off.
Written Giude.....
Click here
Video Guide.....
[ Invalid YouTube link ]
Then when the door card is off, follow the instructions in the review as to wiring and coding.
Hope this helps.
EDIT: Will add the door card removal guide to the review.
« Reply #41 on: January 29, 2013, 11:21:05 am »
can you pick up the module numbers with vcds or will I need to drop off the door panels? To find out what gen I got.
Also does any one know the part numbers for the repair wires to do this mod on a 2dr if I go the oem route?
« Reply #42 on: January 29, 2013, 11:24:13 am »
Offline r32son
« Reply #43 on: January 29, 2013, 06:37:11 pm »
I'm going to order those bold sport ones, bloody hell their bright!
« Reply #44 on: January 29, 2013, 11:21:22 pm »
Found this guide if anyone looking to fit them there selfs
http://www.r32oc.com/topic/25982-mk5-golf-r32-door-exit-warning-lights/
