Author Topic: LED Door Warning Lights - Review  (Read 44295 times)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: LED Door Warning Lights - Review
« Reply #60 on: January 31, 2013, 10:41:22 pm »
Any LEDs that won't throw a fault Ed? Or maybe a resistor?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #61 on: February 01, 2013, 09:11:45 am »
try a resistor
Cluster and Key coding
Location Great Yarmouth
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #63 on: February 03, 2013, 07:31:18 pm »
I don't know, give it a try and see :wink:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #64 on: February 03, 2013, 08:35:52 pm »
Right done, i'll report back and let you all know  :P
Offline GS WAX
« Reply #65 on: February 07, 2013, 06:57:35 pm »
Urgent help needed please... I have repair wire 000 979 019 and it does not fit into the terminal block of the door controler, should they have to be forced in... This does not look very close to fitting.
Help please the car is in bits, I'm getting cold and want to go home.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #66 on: February 07, 2013, 07:24:12 pm »
They do fit, but will need gentle persuading. Check your putting it the right way in and gently push in, I used one of the misuses hair grips to push down until clicked into place.
Take your time, don't rush it, that's when things always go wrong  :happy2:
Offline GS WAX
« Reply #67 on: February 07, 2013, 08:45:18 pm »
I failed....
The pin is bigger than the hole in the connector block,plus there is something, that i dont know what to call it(a square in one of the corners of the block), in the way, have pics on the  iphone but bont know how to post them here, help again needed  :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #68 on: February 07, 2013, 09:11:40 pm »
Which controller are you doing front or rear? Which Gen controller?
Which pin position on the block?
Upload pictures to photobucket, then copy and paste the image code in your post  :happy2:
Offline GS WAX
« Reply #69 on: February 07, 2013, 10:39:30 pm »
Car is a May2008 built ED30 3 door,
Started at passenger side door,
 I Have this controller (btw  Any idea as to what type of controller it is?  GEN 3 min or max)
Trying to fit into  pin numbers 18 and 19
The offending items
The repair wire just will not fit in that hole without butchering the connecter block.
Will call  TPS in the morning to check they have supplied the correct part.
Cheers for the help so far
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: LED Door Warning Lights - Review
« Reply #70 on: February 08, 2013, 06:20:48 am »
That yellow cable seems really thick! My one was thin as the factory ones going into the controller
Sent from my GT-I9300 using Tapatalk 2
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #71 on: February 08, 2013, 07:21:44 am »
Yeah dude that's the wrong wire. They must have given you the wrong one.
000 979 019 fits fine.
Offline GS WAX
« Reply #72 on: February 08, 2013, 09:37:27 am »
All is  sorted now, tps supplied me a  979 019E and not an 019
Thanks for the help
GS
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #73 on: February 08, 2013, 11:22:36 am »
BTW to answer your question, thats a gen 3 controller. MIN or MAX you'll need to scan with VCDS  :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #74 on: February 08, 2013, 06:09:42 pm »
Ed would these do the job?
http://www.ebay.co.uk/itm/XTEC-LED-LOAD-RESISTOR-KIT-FOR-W5W-501-T10-5w-LEDS-/271051019648?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f1be65580
So these arrived this morning. They work and stop the error code but cannot fit them inside the unit as the LED's are too big  :sad1:
Anyone know of a smaller resistor kit?
