Author Topic: inner tail light mod  (Read 14785 times)
Offline Sie
Re: inner tail light mod
« Reply #15 on: December 25, 2011, 09:36:14 pm »
How? Please tell
Surely if you use LEDs and tap off orginals it wont see them?
Fettled Laser Blue '05 GTi 5dr
Offline skard
  • -Receive: 245
« Reply #16 on: December 25, 2011, 09:38:57 pm »
Did you use LED's or wedge filaments?
Did your light output look equal as well?
Offline perky85
« Reply #17 on: December 25, 2011, 09:42:25 pm »
I used standard 501 bulbs.
They are a little brighter than the outer ones, could do with a lower wattage bulb to be honset.
The problem is fitting 501's as there is absolutely no room between boot lid skins!!
Offline skard
  • -Receive: 245
« Reply #18 on: December 25, 2011, 09:49:55 pm »
Nice, so how did you get around the bulb out error?
Offline perky85
« Reply #19 on: December 25, 2011, 10:03:17 pm »
disable bulb monitoring on whatever light source you take the power from
Offline skard
  • -Receive: 245
« Reply #20 on: December 25, 2011, 10:20:08 pm »
Cool, I've seen that option :happy2:
Last question - did you take your feed for each cluster from just one side, or did you take the left feed from the left and right feed from the right (if you know what I mean)?
Offline KevMK5
« Reply #21 on: December 25, 2011, 10:23:44 pm »
hmmm this is a mod i would love to do on mine,
im guessing it can be done using the standard design rear clusters then. doesnt need to be the LED valeo type ones.
Laser Blue GT Tdi 140
Offline Zaf2616
« Reply #22 on: December 25, 2011, 10:31:06 pm »
Where is the option? I could only ever find disable cold lamp diagnosis...
Offline perky85
« Reply #23 on: December 25, 2011, 10:36:23 pm »
I took the feed from one side run it into the boot lid than run the power from the one side.
Technically, it shouldn't be done like this. But it works  :happy2:
Offline perky85
« Reply #24 on: December 25, 2011, 10:38:43 pm »
This is correct, cold lamp diagnosis.
Sorry, being in the trade I talk like everyone else understands what I'm talking about,  :laugh:
Offline skard
  • -Receive: 245
« Reply #25 on: December 25, 2011, 10:41:26 pm »
I might rig up this setup and take left power from nearside loom and right from offside loom. That way it's not drawing the load from one wire, see if it still results in a canbus error, although i think it will.
Offline perky85
« Reply #26 on: December 25, 2011, 10:46:32 pm »
I got swarf in front of the reflectors after drilling the holes, looks a bit of a mess, but this was just a test to see if i could get it to work.
Prob wont be doing it again
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #27 on: December 25, 2011, 11:59:08 pm »
What would be a less powerful yet suitable bulb?
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline skard
  • -Receive: 245
« Reply #28 on: January 04, 2012, 11:23:05 pm »
Still contemplating doing this, what about a bulb like http://www.ebay.co.uk/itm/2-Pcs-T10-W5W-5050-SMD-Car-LED-Wedge-Light-Bulbs-Red-12V-/130621576560?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e69a71570?
Small profile, and tiny power draw so it may not cause an error.
Would just be concerned with the colour match in using an SMD against a filament wedge.
Offline Jaywoo-GTI
  • -Given: 38
« Reply #29 on: January 05, 2012, 11:44:48 am »
How about taking the feed from the number plate light and fitting some non-canbus leds(low resistance) in the number plate bulb holder i.e. the extra bulbs in the rear light would create the needed resistance for the cold lamp diagnosis?
