Author Topic: Noises from front suspension  (Read 7178 times)
Offline Black9
  • -Given: 35
« on: October 28, 2012, 04:53:43 pm »
Recently done the bolts and spacer mod on my ED30 as I was hearning noises coming from my front suspension. Thought it would cure it but it never. Had a good look over the suspension with a mechanic and from what he can see the ARB links etc look fine. He thinks it may be the CV joint? Sometimes get a clicking noise on full lock and also get a knocking noise over uneven surfaces or speed bumps.
I'm thinking it maybe the upper suspension mount bearings. Car has 70,000. The CV joints aren't split and visually look fine... How common are worn CV joints. Should I just go ahead and get the bearings replaced?
Offline GOLDENBOY
Re: Noises from front suspension
« Reply #1 on: October 28, 2012, 05:43:50 pm »
Im having the same noise  :sad1: when turnin full lock, get knocking noise, and driving slowly i can hear noise coming from front suspension mainly drivers side like something loose, be interesting to know what it is too!!  :confused:
Candy white edition 30 / Revo stage 1 / Itg maxogen / xenons/ R32 brakes front/rear/ H&r springs / cruise/ open fogs/ Rns-510
« Reply #2 on: October 28, 2012, 06:27:56 pm »
Have you checked out the bush brackets on your Anti Roll Bars?
Offline GOLDENBOY
« Reply #3 on: October 28, 2012, 07:55:52 pm »
you could well be right there could well be the bush brackets on the Anti roll bars ( Redrobin ) :happy2: until i get it on the ramp, looked at properly im in the dark,  :sad1: dont mean to jump you thread (Black9)
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #4 on: October 28, 2012, 08:27:44 pm »
Subscribed to this thread as I have a "click" from passenger side when I turn right or the drivers side wheel goes over a bump. Replaced top mounts & bearings and drop links and it's still there  :sad1:
No play in the wheel at all so could be a knackered shock absorber  :sad1:
Good luck in solving yours  :happy2:
Offline Black9
  • -Given: 35
« Reply #5 on: October 28, 2012, 08:30:57 pm »
I'll check the brackets too. Don't be afraid to hijack, any opinions help
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #6 on: October 28, 2012, 08:45:22 pm »
Something else it could be on yours is the subframe bolts? They stretch over time and allows the subframe to move about a bit  :sad1:
Offline Baz300
« Reply #7 on: October 28, 2012, 09:07:45 pm »
I had the clicking/crunching noise on full lock on  mine and a new outer CV joint solved it.
I've just had my driver side wheel bearing go this week, it's making a ratteling noise and is the 3rd bearing to go on my car in the last 2 months and I'm only on 44k miles. The bearings don't seem to whine on the golf like most cars they just seem to collapse without warning.
Offline Black9
  • -Given: 35
« Reply #8 on: October 28, 2012, 09:32:43 pm »
That's the first thing I replaced along with the washers. Thought this would solve it, it never:(
The outer CV boots aren't leaking, how can I tell if it's them without actually replacing them. Also can I replace as singles or pairs only?
Offline Baz300
« Reply #9 on: October 28, 2012, 09:56:49 pm »
Not sure how to check them
There was an advisory on the last mot from my car that the boot was split so it made it easy to diagnose for me.
Best bet is to get it booked into a decent garage and get them to look over the car.
I have made the mistake of replacing lots of parts on cars before to find the cause of the problem and I would of been cheaper just getting the car into the garage in the first place.
Offline Black9
  • -Given: 35
« Reply #10 on: November 01, 2012, 04:35:37 pm »
The noise is still there, I'm convinced the knocking over speed bumps is upper mounts bearings which I'm going to get replaced as a pair.
As for the clicking noise it only happens occasionally from the left front corner of the car & only when turning the steering wheel to the right. Sounds like a CV joint to me. Most likely the outer one. It's not split but everything else visually looks fine inc ARB links etc... So I can rule them out
Having it checked over this weekend hopefully, if nothing else looks out of place I'm gonna go ahead and order the outer CV joints. Should I be ordering in pairs or is a single CV joint ok? Any ideas what VW charge for CVs?
« Last Edit: November 01, 2012, 04:37:42 pm by Black9 »
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #11 on: November 01, 2012, 05:48:45 pm »
^^ keep us informed of shat you find :happy2:
Offline Black9
  • -Given: 35
« Reply #12 on: November 01, 2012, 08:00:40 pm »
Will do. Should I be buying the CV joints in pairs or singles ok?
Offline keano
  • -Given: 79
« Reply #13 on: November 02, 2012, 12:38:05 am »
I had this earlier in the year. Turned out to be my shocker.
HTH  :happy2:
Offline Black9
  • -Given: 35
« Reply #14 on: November 02, 2012, 10:33:04 am »
HTH  :happy2:
Both the knocking and clicking noise? It may well be the shocker as its lowered on VWR springs on stock dampers
