Author Topic: Oil over max  (Read 1239 times)
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Oil over max
« on: October 29, 2012, 05:37:44 pm »
Just topped up. Level was mid way between min & max. Put in approx 700 ml.
dipstick reading is now above the max. It's gone onto the cable part of the dipstick.
Should I drain some out?
'07 Red manual
Offline graeme
Re: Oil over max
« Reply #1 on: October 29, 2012, 05:43:55 pm »
yes , to much oil can be just as bad as not enough  :happy2:
Re: Oil over max
« Reply #2 on: October 29, 2012, 05:49:13 pm »
The trick when topping up with oil is to do just a bit at a time and check the dipstick after each bit. It's bad to overfill.
Re: Oil over max
« Reply #3 on: October 29, 2012, 07:37:25 pm »
Syringe and feeding tube down the dipstick tube and you're half way home.   :smiley:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Oil over max
« Reply #4 on: October 29, 2012, 07:40:18 pm »
Just drained a little from the sump. Topped up again, a little more cautiously this time - lesson learned!
BTW you don't need to remove the splash guard to access the sump plug.
Thanks for the advice folks  :smiley:
Too late for the syringe Bacillus, but would be easier than getting under the car for sure :happy2:
PJ
'07 Red manual
