Author Topic: Budget 440 for 4 premium Tyres - Help Please  (Read 10559 times)
Offline winrya
Re: Budget 440 for 4 premium Tyres - Help Please
« Reply #30 on: October 31, 2012, 08:38:43 pm »
i get very confused wit the Pirelli P Zero structure if someone can explain?
At the top of the tree is there just a P Zero?
Then sub varieties of Rosso, Nero, Cinturato? If so how do you know which of these are the highest perfromance tyre?  :confused:
Yes the p zero is the top spec version.
Summary of the evo review is here http://www.tyrereviews.co.uk/Article/2012-EVO-Max-Performance-Tyre-Test.htm
scottm72
« Reply #31 on: October 31, 2012, 11:36:45 pm »
Just a heads up. You don't need the same tread pattern on the same axle mate.
....Surely you meant to write that you DO need the same tread pattern on the same axle, and you meant that front tyre treads could be different from rear tyre treads. Ideally it's better to have the same tread patterns all round and deeper treads on the rear - Sticky Vicky must be obeyed!
From experience, avoid running Directional treads on one axle and Asymmetric treads on the other - It kicks in the ESP more often and can feel very snatchy to drive.
No. It's a bit of a dated practice. There's absolutely nothing wrong with running different tread patterns on the same axel. I'm not saying do it deliberately but if you've got a good conti that's out of production there's no need to bin it off. Especially if its in nearly new condition.
....Sorry but I'm not sure I can agree.
If two tyres have a different tread pattern then they are very likely indeed (almost 100% certain?) to have different properties in their construction and/or rubber. For example, tyre wall stiffness. Consequently, under typical stresses and UK road conditions the car's ESP system is likely to kick in as it reads one wheel (tyre) behaving differently.
This is not necessarily a problem in itself inasmuch that the ESP will 'save the day' and help you out of trouble. However, I know from direct experience that the ESP kicking in due to tyre differences is very unpleasant and actually the first few times it happens it's quite scary until you realise what is happening and keep your foot planted through it. And that experience is with a Quaife diff installed.
Another aspect of this is that tyre wear rate is likely to be different between different tyres and again it's far from ideal to have uneven tyre wear on an axle.
So, until someone can fully explain otherwise, I don't agree that your advice on this is a good practice and especially not for any spirited driving (which GTI's are designed for).
red is correct here in every area he describes
of course you can use different tyres on the same axle if you want inconsistences, if it was a micra or a fiesta or something then stick anything on, but were talking about a performance car here, other thing to remember is the water dispersal will be different on a diff tread pattern.
to run a car like a gti and want it to perform well common sense must be used.
personally if I bought a gti and it had 4 brand new tyres on it with one being a diff tread pattern it would be off asap and replaced for the right one, if the tread pattern is no longer available then at the very least match up the axles with the same tyre.
if you want to get it even more right then if you are on the search for 1 tyre then try and get a similar dot code tyre,,, the year and week of production of every tyre is stamped on the sidewall, so something like a august 2012 produced tyre will act differently than a tyre that rolled of the production line in say 2010, hence the reason why all major tyre manufacturers advise to discard a tyre after 4 years if I remember right, even if it is brand new and been sitting on a garages shelf, a tyres sidewall strength WILL degrade over this time and will then act differently on the road.
how many people out there knew the exact date of production is stamped on their tyres ?
look on the sidewall, there will be a 4 digit code, it can be on the inside or on the outside of the tyre, if you cant see it go to the other side of the car and it will prob be on the outside of that one,,, the 4 digit code will be for example 2611 in a little rectangle circular box where all the other things are stamped like the tyre size, 2611 will mean the tyre was made in the 26th week of 2011.
when I bought my car 2 months ago it had 36k miles on it and 2 of the tyres where original 2008 dot codes, salesman tried to tell me the tyres where 6 months old lol, once I pointed this out he just shut up.
every tyre in the uk has a dot code
diff tyres on same axle ? not on a gti dude but your car
Offline ianv5
« Reply #32 on: November 01, 2012, 05:16:14 am »
« Reply #33 on: November 01, 2012, 08:53:11 am »
As scottm72 very rightly points out: water dispersal will be different on a different tread pattern. I forgot to mention that and it's actually very important indeed. We get a lot of rain nowadays in the UK.
I didn't realise that tyres were date stamped (moulded) - We learn something new everyday  :happy2:
Offline Mk5 GTian
  • -Receive: 37
« Reply #34 on: November 01, 2012, 09:14:22 am »
Every day's a school-day Robin!
 :grin:
Offline Mk5 GTian
  • -Receive: 37
« Reply #35 on: November 01, 2012, 09:20:58 am »
Costco have their 20% off sale starting from 5th November, when I took them on that discount back in June it was £440 for all 4 Michelin pilot sport 3's supplied and fitted with Nitrogen  :happy2:
Is that the Costco near Croydon in Sanderstead Jussa?
« Reply #36 on: November 01, 2012, 09:31:36 am »
 :grin:
....Yes please!
scottm72
« Reply #37 on: November 01, 2012, 11:13:59 am »
 :grin:
....Yes please!
coooool picture, first pic to go into my new windows 8 pc
« Reply #38 on: November 01, 2012, 01:00:12 pm »
.... :happy2:
Note what's written on the school blackboard: Lenny Kravitz "Let Love Rule":
^ Some very tasty solos in this tight performance, especially the sax  :notworthy:
Offline Jussa
  • Bicester
« Reply #39 on: November 01, 2012, 01:44:00 pm »
Nice one Jussa! My dream tyre (that does sound very nerdy), that'll do me 440 all in. Where's Nitrogen though?
....I think he means filled with Nitrogen within the price of supplying and fitting.
 :ashamed: :ashamed: :ashamed: Oh. That's quite embarassing!
So if you buy from Costco, where do get the tyres fitted please Robin?
They fit them for you all included in the cost  :happy2:
Hi Mate,
Do Costco just sell the tyres as well? I only ask as my Father-in-law has a Cosco account but he is up in Liverpool and I am down South (In Afghanistan at the moment!) They are coming down to see the wife in a couple of weeks so I was just wondering if they could get the tyres for me. Then i can get them fitted at a later date.
Yes mate you can buy them and have them fitted later  :happy2:
Offline Kalpsn2000
  • -Receive: 56
« Reply #40 on: November 01, 2012, 02:31:13 pm »
Didn’t know that either, will check mine out later (thanks Scott :happy2:)
 :grin:
....Yes please!
Where do I sign up for that class :drool:
Offline Mk5 GTian
  • -Receive: 37
« Reply #41 on: November 01, 2012, 05:30:15 pm »
 :grin:
....Yes please!
Ha ha, I knew that would inspire you to come  up witrh a suitable photo! Brilliant!
Offline Mk5 GTian
  • -Receive: 37
« Reply #42 on: November 01, 2012, 05:34:34 pm »
Great news, the Continental Sport Contact 2's on the back are like new, and they couldn't find any nick on them at all. Must have imagined it!
The fronts were 1.6mm, so I changed them for Michelin Pilotsport 3's for 121 a corner, fitted, balanced with new valves and a free alignment check at Tyre City. They price-matched the Camskill price and added their fitting costs. Brucie Bonus!!
homesqueeze
« Reply #43 on: November 01, 2012, 06:12:00 pm »
I have always checked the tyre date code after reading about it years ago. Needs to be checked when you get new tyres to make sure you're not being fobbed off with old degraded rubber. Interestingly my new set of GY Eagle F1's was only a few weeks old when I got them. Super fresh!
scottm72
« Reply #44 on: November 01, 2012, 10:11:40 pm »
yeah same here with my eagles,,, still hot from the factory lol
