Author Topic: Front left wheel vibration  (Read 1863 times)
Offline cass
« on: October 30, 2012, 10:50:05 pm »
Ok folks hope you can help....my mk5 golf gttdi had a vibration when turning left at low speed , anyway didnt bother me much untill the mot when it failed on front wishbone bushes. Got these replaced and passed the mot but the vibration still rears its ugly head and the tyre seem to be wearing faster than usual......has anyone experianced/fixed this problem?
Re: Front left wheel vibration
« Reply #1 on: October 31, 2012, 08:52:09 pm »
Checked the alignment and wheel balancing?
Offline cass
« Reply #2 on: November 01, 2012, 08:02:04 pm »
had a 4 wheel alignment done about three weeks ago, gonna try swapping the tyres round tomorrow
Offline aslz78
« Reply #3 on: November 02, 2012, 02:47:44 pm »
Just to rule out something simple, check all the nuts are fully tightened. You'd be suprised how often i notice it on the cars at work!
Offline cass
« Reply #4 on: November 04, 2012, 01:34:12 pm »
Changed the tyres over on friday and tried moving things with a big bar.....everything was solid apart from the rear bush,should this have play in it?
Also what are the symptoms of top mounts going? and what are the symptoms of a cv joint going?...oh and nuts are on nice and tight...checked them on friday
Offline Geoffcarragh
« Reply #5 on: November 09, 2012, 02:42:34 pm »
Could be a wheel bearing??
Do you hear a vibration/noise when turning right at speed (ie. when the cars load is transferred onto the front left wheel). the noise will disappear when turning right and the left wheel is not taking as much load.
This is a relatively cheap fix at about £70 incl labour.
'05 Silver, 5 door, 18'' Monza II, Leather, Lux Pack, Gear Stick, CD changer in armrest, colour coded rear bumper, upgraded DV,
Offline Baz300
« Reply #6 on: November 09, 2012, 08:15:20 pm »
Wheel bearing is around £100 for a front one on a mk5
Then around an hours labour min £50
« Reply #7 on: November 09, 2012, 08:30:27 pm »
I had mine done on a warrenty, the reciept was for around the £70 mark.
Although that was a few years ago and at an independent garage.
Offline Baz300
« Reply #8 on: November 09, 2012, 09:52:26 pm »
And that's ECP's prices
Offline cass
« Reply #9 on: November 10, 2012, 01:38:15 pm »
My wife took the car to get the alignment done again this week, the guy said it was well out again????anyway he corrected it but im still getting the feeling. Yes the noise does transfer when changing direction but i jacked the car up and had a push and pull of the wheel but there was no movement????im well confused.
