Author Topic: Most suitable/Best oil?  (Read 93021 times)
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
Re: Most suitable/Best oil?
« Reply #30 on: May 07, 2010, 11:51:44 am »
After doing a bit of research, I found this post particularly useful :
http://www.golfgtiforum.co.uk/index.php?topic=65779.0
I've decided to continue running the Castrol SLX Powerflow Longlife III SAE 5W-30 50400/5070 oil but have now changed from Longlife service interval to fixed Distance&Time @ every 15,000 KMs.
Glad my nuggets of info are getting noticed! :happy2:
Very interesting read TT, can I ask a simple question which I have never been able to find the answer too?  Using VCDS I looked at the servicing and oil quality reading from my car which from memory was "2" but no where can I find on what scale, is it 1-10 or 1-5 and if so does it start at 0 when refreshed or new, and if so do you have a recommendation, or advice on at what value a refresh should be considered (outside of your existing recomendations)????  :smiley:
I don't know what the actual readings mean.  However, if the car is coded for Time and Distance, these readings from the oil quality sensor are ignored.
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #31 on: May 07, 2010, 12:20:00 pm »
Cheers TT, if you dont know its probably not worth knowing  :wink:
Offline Mako V12V
    • Astons, Porsches & Golf GTIs
« Reply #32 on: May 20, 2010, 09:49:14 pm »
I've just had my Ed30's 2nd service carried out at a local VW MD. The first service oil used was Helix 5W30 (previous owner and different VWMD) and now my local has done the second service using Helix 10W 40.
I asked them about this and they said the 10W40 is better quality oil....is this true?
Can 5W30 and 10W40 be mixed as i still have nearly 1L of 5W30 left as top-up oil?
Car is exactly 2 years old with near 17k on the clock.
Cheers - Phil
VW Golf Edition 30, Candy White, 3dr Manual. Plus a stunning Aston Martin V12 Vantage!
  • -Given: 88
  • -Receive: 95
« Reply #33 on: August 30, 2010, 03:02:16 pm »
Nope.  The 10w40 is most likey a semi-synthetic - so how can that be better than a fully synthetic (from the same oil company).  In a turbo engine - you categorically do NOT want semi-synth - you will coke up your turbo bearings.
This is just another example of main stealers being incompetent.  ETKA categorically does NOT authorise anything other than LongLife 3 oil to be used in the GTI, even if it is on T&D servicing - so go back to the stealer and demand they change it for the correct oil.
Yes, they can both be mixed (though ideally no more than half a litre).
Offline mvb12
  • -Receive: 64
« Reply #34 on: March 11, 2012, 08:10:51 pm »
sorry to bring this old thread up again - best is castrol A3 10W-40 a good all to go in the GTI.
is this a semi or full engine oil?
Offline s2martyn
« Reply #35 on: March 12, 2012, 11:22:50 am »
does no-one use the longlife 3 from tps??
been using this in all vag cars for years..
very well priced approx £25 a gallon
Offline fsgti
« Reply #36 on: January 08, 2023, 06:46:27 pm »
Anything with VW 504.00 or 507.00 on the label.  This is the spec for all VW engines now.
I personally use Fuchs oil as its the OE oil from the factory and its reasonably priced.
It say 504 00, 502 00 in owners manual for non longlife service vehicles
« Reply #37 on: January 09, 2023, 03:10:40 pm »
Is quoting someone from 13 years ago really necessary?  :grin:
