Author Topic: Sprained ankles  (Read 3409 times)
  • -Receive: 427
Re: Sprained ankles
« Reply #15 on: October 31, 2012, 10:16:32 pm »
Get yourself to the GP fella if you don't know how this happened, could be anything.  :confused:
1. Nobody uses compression anymore.
2. You don't get DVTs in the foot/ankle.
3. MTFU
If someone has DVT in the lower limp can this not cause swelling in the ankle?
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Sprained ankles
« Reply #16 on: October 31, 2012, 11:05:09 pm »
Theoretically DVT can happen anywhere in the distribution of the major veins in the leg, which in practical terms we're talking calf area and above. This is where blood stagnates and clots ("thromboses").
From the photo it doesn't look like a typical DVT, but you can't see the calf (the entire leg can swell - if this were the case I'm sure the OP would have informed us). As you rightly point out if concerned get it checked.
« Last Edit: October 31, 2012, 11:06:56 pm by sub39h »
PLANS: Stage 2+
Offline c0v3rt
Re: Sprained ankles
« Reply #17 on: October 31, 2012, 11:09:37 pm »
I'd recommend 'contrast bathing' - hot water then ice cold water, 10 mins each, and repeat!
Suffered many a twisted ankle when a bit younger through skateboarding - once resulted in a full dislocation (popped it back it myself) - 6 weeks on plaster and never really fixed itself, and now regularly twists itself just walking! Has been a lot better since getting a dsg car though.
  • -Receive: 291
Re: Sprained ankles
« Reply #18 on: October 31, 2012, 11:19:02 pm »
You don't get isolated ankle swelling. The whole calf may be swollen and as part of that the ankle.
OP says he has sprained his ankle. The problem is that OP hasn't a clue and should get it checked out. If it's purely a sprain, my first post in this thread stands.
Offline ArildStavrum
Re: Sprained ankles
« Reply #19 on: November 01, 2012, 11:39:20 am »
 :signLOL: and i young sir will raise you this one, i climbed a 45m tower crane with that like that. Needless to say i struggled to get down.
[/quote]
camera trickery!!! :happy2:
looks nasty.
Offline Moz
Re: Sprained ankles
« Reply #20 on: November 01, 2012, 01:43:20 pm »
I've take some advice, it's 100% gout.
Most painful thing I've ever had.
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Sprained ankles
« Reply #21 on: November 01, 2012, 04:21:25 pm »
Plenty of (clear) fluid and off the booze!
PLANS: Stage 2+
  • -Receive: 291
Re: Sprained ankles
« Reply #22 on: November 01, 2012, 05:27:55 pm »
Sudden changes like immediately stopping alcohol can also precipitate gout.
Re: Sprained ankles
« Reply #23 on: November 01, 2012, 05:36:23 pm »
Blood test proved as it's not the typical joint for a first attack of gout...
Re: Sprained ankles
« Reply #24 on: November 01, 2012, 05:40:11 pm »
I would trim your pubic hair in the first instance...   :scared:
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Sprained ankles
« Reply #25 on: November 01, 2012, 06:45:44 pm »
He would have to wait until it settles before checking a urate, no?
But you're right, gout wouldn't have been my first thought.
« Last Edit: November 01, 2012, 06:49:41 pm by sub39h »
PLANS: Stage 2+
Re: Sprained ankles
« Reply #26 on: November 01, 2012, 07:23:14 pm »
[/quote]
Correct but the statement " it's 100% gout" suggest to me that either he's known to have an elevated uric acid level or aspiration of the joint yielded the characteristic urate crystals in joint fluid.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Sprained ankles
« Reply #27 on: November 01, 2012, 08:35:31 pm »
I was just going to suggest gout if anyone believes that!  :grin:
Offline Moz
Re: Sprained ankles
« Reply #28 on: November 01, 2012, 08:49:00 pm »
It all makes sense, I've still not been docs yet as the pain is too bad to go out and logistically it's a nightmare.
However from reading of symptoms, it's all there.
I had the worst pain of my life with it today, or just utter pain, like out and out pain on the whole ankle. Towards the latter stages of today the pain was focused along the big toe bone.
The swollen areas are red, and painful to touch, any kind of bang or knock is very painful. It came on one morning after waking up.
Everything points towards gout.
This is todays image, elephant foot not as bad, but redness has come out more now.
« Last Edit: November 01, 2012, 08:52:28 pm by Moz »
Re: Sprained ankles
« Reply #29 on: November 01, 2012, 09:42:22 pm »
Your doctors will have an emergency doctor on call 24 hrs a day.
Call NHS 24 if not, they can send a doctor or an ambulance.
You need to get that seem to as soon as possible.
