Author Topic: Aux heater?  (Read 4571 times)
Offline edd666999
  • -Receive: 89
Aux heater?
« on: November 01, 2012, 11:38:46 pm »
http://www.golfmkv.com/forums/showthread.php?t=113468
Anyone done this?
Its getting cold and following this apparently you get warm air after 30 seconds!
Re: Aux heater?
« Reply #1 on: November 01, 2012, 11:40:53 pm »
Thought that this was only for diesels...
Offline chrisr763
  • -Receive: 62
Re: Aux heater?
« Reply #2 on: November 01, 2012, 11:45:51 pm »
Well by the looks of things, can be fitted to GTi's also?  :ashamed:
Offline Pashka
Re: Aux heater?
« Reply #3 on: November 01, 2012, 11:50:45 pm »
There are two diff versions. E comes with "mainboard" inside, F - without.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline jedi-knight83
  • -Receive: 41
Re: Aux heater?
« Reply #4 on: November 02, 2012, 12:26:21 am »
would love to do this on my caddy tdi... takes ages to heat up
wonder if its the same bits.
Offline SRC
  • -Receive: 27
Re: Aux heater?
« Reply #5 on: November 02, 2012, 05:39:42 am »
Mmmm... I love my heated seats this time of year!
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods:  Seat inserts and a VW bottle opener.  Each worth 20bhp.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Aux heater?
« Reply #6 on: November 02, 2012, 08:26:25 am »
They are normally fitted to TDI's.
I have a spare one if anyone fancies a retrofit
Jas
VCDS (Preston, Lancashire)
Offline skard
  • -Receive: 245
Re: Aux heater?
« Reply #7 on: November 02, 2012, 08:35:21 am »
Mine packed in last year, replaced it and wished I didn't bother.
It turns really cold air to almost lukewarm in a few minutes, don't expect  instant warm air!
Offline SI-R32
  • -Receive: 126
Re: Re: Aux heater?
« Reply #8 on: November 02, 2012, 09:49:52 am »
Put version E in about a year ago, it does help u defrost the windscreen a little quicker, but as said its lukewarm, its a 1kw heater which on 12 volts can draw 80 amps, VW changed the spec after a few years due to poor connections heating up and causing fire, unfortunately if you want to add to gti you will need version E as it connects to can bus version F runs off diesel ecu, so cannot be Retro fitted, there also really hard to come by as everyone has F's but no E's
Offline Timi8888
Sig to big.
