Author Topic: GTI DSG Rev counter  (Read 1904 times)
Offline vik2001
GTI DSG Rev counter
« on: November 03, 2012, 11:52:13 pm »
question for u guys.
on a DSG what rev mark on the counter, should the gears be changing from 4th to 5th
i noticed when going from 3rd to 4th and i put my foot down the gears dont change sometimes till around 50-70 mark on the rev counter...  is this right?
Offline edd666999
  • -Receive: 89
Re: GTI DSG Rev counter
« Reply #1 on: November 03, 2012, 11:56:04 pm »
unless im getting this wrong you want to know at what revs should a dsg car change from 4th to 5th?
And the answer is it depends on how hard you are accelerating.
if im wrong can you rephrase the question ?
Offline vik2001
« Reply #2 on: November 04, 2012, 12:06:09 am »
correct what rev should a dsg change from 4th to 5th appox in D mode when i am accelarating hard.
im finding that mine is not changing for 3rd to 4th or 4th to 5th at the correct times ONLY when accelerating hard.  it does eventually change gears but only when rev counters hit high mark
Offline mad_pete
« Reply #3 on: November 04, 2012, 09:20:33 am »
If you have your foot down the dsg changes up late. Which is what you want.
Offline Black9
  • -Given: 35
« Reply #4 on: November 04, 2012, 09:35:15 am »
The only times I'd be giving full acceleration are in S or M mode. Doesn't make much sense in D. As previously mentioned the box will change up later in the revs the harder u accelerate. This way u will get max performance for the selected gear
« Reply #5 on: November 04, 2012, 09:55:37 am »
The only times I'd be giving full acceleration are in S & M mode.
Changed that for you :signLOL:
Offline Statller-Stevo
« Reply #6 on: November 04, 2012, 10:50:53 am »
 :surprised:         :signLOL:
Hell don't let Robin see this !!
Offline vik2001
« Reply #7 on: November 04, 2012, 01:52:29 pm »
thanks guys
i had the DSG reset via VAG COM today.  its made a subtle difference and seems more responsive.  also getting away in first gear is alot smoother than before.  theres no jerk pulling away.  think im happy with it now.
