Author Topic: MK5 HVAC/Climate Control expert needed!!  (Read 14355 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=6vmd2gh6m9ib02b5n50kuanooe&/topic,19740.0.html
Re: MK5 HVAC/Climate Control expert needed!!
« Reply #15 on: November 07, 2012, 04:16:38 pm »
Yeah... and which plugs to pull etc...  :happy2:
Offline Squeeguk
« Reply #16 on: November 07, 2012, 07:23:30 pm »
I have a couple of links below, one is how to take the glove box off and the other shows the picture of the flap motors.
Glove box:
http://www.golfmkv.com/forums/showthread.php?t=96856
Flap Motors:
http://vwnavi.com/volkswagen-factory-fit-navigation-systems/rns-510-mfd3-navi-system/9170-climatronic-screen-29.html
In the picture above, you can see the flap motor assembly, the newer one with one motor on the left and the older one with two motors on the right. You will most likely have the one with two motors. There are two blue plugs plugged into the motors, you can get to them with the glove box off. They will be to the right of the assembly. a bit tricky to remove the rear one, but it can be done. You can actually see the two blue plugs hanging in the 3rd picture down.
Hope this makes it clear, if not, let me know and I will see what else I can dig up.
« Reply #17 on: December 23, 2012, 09:58:32 am »
Really really really really really really really really really really really really really  getting beefed off with this now.
Drive back from malvern last night car just steams up because there is no air coming out of the vents... not even the front de-mist... made for a very very very very miserable and hard journey.
Got back at 00:30 ad straight out with VCDS....
NO fault codes... so I perform a "Flap Basic Settings" and boom... instantly starts blowing air out of the vents.
I checked ran all the output tests and all perform fine.  :confused:
WHAT THE DEUCE IS GOING ON????
 :fighting: :fighting2: :sick: :fighting2: :fighting:
« Last Edit: December 23, 2012, 10:00:37 am by richwig83 »
« Reply #19 on: December 24, 2012, 12:12:03 am »
or carry your lap top with you :laugh:
« Reply #20 on: December 24, 2012, 12:21:17 am »
LOL.
Ta damo. First thing is to remove the glove box and have a nosey around. But I think that's the part which is playing up :-)
« Reply #21 on: December 27, 2012, 04:13:34 pm »
Glovebox out...
Sat in car an hour with the blowers on to see if anything would stop working.... and surprise surprise... all worked perfectly!
Gonna keep the glove box off for the foreseeable, so i can find out what the hells going on.
Offline Jme
« Reply #22 on: December 29, 2012, 12:18:44 pm »
Oh dear looks like I have the same problems and I can not get it to blow warm air to the footwell at any time. Here comes the nipped fingers and swearing again  :signLOL:
Mk5 GTI manual 3Door.
Mods to date. De-badged, led/smd inside and out.
Mods to do.    Led/smd puddle lights, satnav, Bluetooth,
                     Induction kit, exhaust, hid/led fog drls, +++
tonker123
« Reply #23 on: December 31, 2012, 11:18:41 pm »
Hello, Did you get this fixed ? I have had the same problem for about a year now.
It kicks in either after 2 hours driving - aircon goes limp and blows next to nothing, even when manually 'forced'. It's rubbish.  It'll be fine the next day.
OR, it comes on when the EML flashes on with a misfire on all four cylinders (After 30 minutes today) that doesn't exist (I'd ideally like to find that fault and fix it too !)
So far, I've dropped a lot of money on inspections with specialists and VW Dealers. No fault codes are recorded anywhere and they can't find any physical faults. It's been serviced, regassed, new filters, run for hours, you name it.... none of it finds any fault. But it doesn't work after a while. I drove the car today (it's my wife's) and it wouldn't even clear the mist caused by our breath off the windscreen..... and I know that tomorrow it will blow brilliantly.
Damned annoying. And the attitude of the dealers is the usual - no sir, no faults recorded, there's nothing wrong with it - the computer says so.... - so any guidance/solution you found would be fantastic.
Thank you.
Offline AliGTI
  • -Given: 28
« Reply #24 on: December 12, 2015, 05:33:21 pm »
Has anoyone got anymore info on this? My car started this last winter. Like everyone else it's only a problem after an hour or so of driving.
« Reply #25 on: December 13, 2015, 12:08:56 pm »
Nope... never got to the bottom of it. But, Ive stopped using my car for long journeys (change in work) so that most of my journeys are now sub 1 hr so I dont notice it these days.
Rich
Offline AliGTI
  • -Given: 28
« Reply #26 on: December 14, 2015, 08:06:07 am »
Rich
I thought this sounded a bit crazy but it seems to have woked. Someone suggested closing the vent on top of the dash. I'm not sure what it actuallly does to help but I drove for over an hour yesterday and the issue seems to have vanished. It's a weird one :/
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #27 on: December 14, 2015, 08:29:38 am »
Top vent takes away all the air to the screen for whatever reason I don't know but once closed, all the air circulation is back to the main vents. Not sure if that's how it's meant to be as I've not rear the handbook yet lol but that's what I figured out after nearly 3 months driving it with less air on the vents.
M
Offline AliGTI
  • -Given: 28
« Reply #28 on: December 14, 2015, 10:58:14 am »
M
Sorry yes I know what it does in relation to the air flow but I can't see how having it shut makes the fan work correctly. Last week after an hour of driving I had no air out of any vents. Now I close the top vent and everything works perfectly.haha
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #29 on: December 14, 2015, 11:44:53 am »
Maybe it's down to the flap motor but I can't be 100% on that sorry AliGTI
Flap motors are cheap on ebay under £20 used.
figured it out at last hahaha... when switched to the top vent, it allows full air to clear the screen doh  :stupid:
M
« Last Edit: December 15, 2015, 04:42:54 pm by r5gtt »
