Author Topic: Folding mirrors not working  (Read 7747 times)
Offline damoegan
« on: November 04, 2012, 12:32:53 pm »
Folding mirrirs not working  :sad1:
It has the folding mirror switch but they wont fold (dont even try..). Not showing a fault code, no fueses gone.... Mirror dip and heating work fine..
Could it be the coding??
2008 57' plate .:R32
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Folding mirrors not working
« Reply #1 on: November 04, 2012, 12:47:02 pm »
Hi
I take it they worked before? or did you see the dial and the folding symbol and thought I have folding mirrors
If the mirror have the puddle light underneath then they are folding, then you have an issue
A scan would be helpful
Cluster and Key coding
Location Great Yarmouth
Offline damoegan
« Reply #2 on: November 04, 2012, 01:03:45 pm »
Only got the car last week Ed and only just tryed them the other day...
Yes, it has puddle lights...
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: November 04, 2012, 01:08:29 pm »
scan required
Offline damoegan
« Reply #4 on: November 04, 2012, 01:09:28 pm »
Full scan or a particular modual?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: November 04, 2012, 01:14:41 pm »
full scan minus your car details (VIN etc)
Offline damoegan
« Reply #6 on: November 04, 2012, 01:19:13 pm »
VCDS Version: Release 11.11.4
Data version: 20120807
Sunday,04,November,2012,13:18:46:08196
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 76
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 KG    HW: 022 906 032 GP
   Component: R32-DQ-EU4      G   1067
   Revision: 1QH02---    Serial number: VWX7Z0G53NB8Z5
   Coding: 0000178
   Shop #: WSC 01269 785 00200
   VCID: 5A955F61953F7DC80F1
No fault code found.
Readiness: 0110 1001
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 011 CC    HW: 02E 927 770 AE
   Component: GSG DSG         081 1406
   Revision: 04608010    Serial number: 00000706191530
   Coding: 0000020
   VCID: 5285B741CDCF4588C71
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0004744
   VCID: 72C517C16D8F2588271
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 79D720ED30F956D066B
2 Faults Found:
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus - Intermittent
00709 - Sunlight Photosensor 2 (G134)
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 01000007380495
   Coding: E68F8F2700041500461400001400000000097B075C000100000000000000
   Shop #: WSC 66565 257 00032
   VCID: 71C718CD68891E90DEB
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 050707 021  0501
   Coding: 00038805
   Shop #: WSC 66565
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     140707 046  0204
   Coding: 00207646
   Shop #: WSC 66565
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 AB    HW: 1K0 909 605 AB
   Component: 5B AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D092XC3
   Coding: 0013634
   VCID: 6CF909B94FABF378EDD
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0013122
   VCID: 8127C80DD8298E10AEB
   Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 974 B    HW: 1K6 920 974 B
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G53NB8Z5
   Coding: 0005403
   VCID: 334BD2C552156C80EC7
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 080707F1001669
   Coding: FF0F074807000001
   VCID: 2F43DEB5BE3D486088F
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   VCID: 364DEBD1416779A8CB9
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1216
   Shop #: WSC 00792 210 91867
Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
   Part No: 1K0 919 887 F
   Component:      Navigation     0030
   Coding: 0000101
   VCID: 3C59F9F97F4BA3F83DD
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
            011 - Open Circuit - Intermittent
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 120B
   Coding: 0000822
   VCID: 3957E0ED707996D026B
2 Faults Found:
00120 - Outside Warning Light/Door exit Light Driver Side
            012 - Electrical Fault in Circuit - Intermittent
00109 - Left Mirror Turn Signal Lamp (L131)
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.141 H08 1901
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 999002085103407F2D02850F7008DAC690BC00
   VCID: 832BC205C2359C00BC7
   Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H07 9001
   Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000822
   VCID: 3A55FFE1757F9DC82F1
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000004
   VCID: F4C991D9979BABB8B5D
Address 56: Radio        Labels: 1K0-035-095.lbl
   Part No: 1K0 035 095 G
   Component:        Radio        0030
   Coding: 0040400
   VCID: 297730AD80D9265056B
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D7FC4BDB4313A70BA3
1 Fault Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
            006 - Short to Plus - Intermittent
End   ---------------------------------------------------------------------
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: November 04, 2012, 01:36:16 pm »
I can see there is a fault on the drivers side
If you do the output tests on that side and see if the functions work
If they don't then there is a fault in the wiring or controller
Offline damoegan
« Reply #8 on: November 04, 2012, 02:01:44 pm »
Never done a output test before, how do I do it?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: November 04, 2012, 02:37:07 pm »
Start vag-com
control Modules > Drivers Door Address 42 > there is a box listed Output tests > Start and click next after each item has been tested
Offline damoegan
« Reply #10 on: November 04, 2012, 03:52:07 pm »
It folds when I do the Output test  :confused:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: November 04, 2012, 03:54:51 pm »
check the switch?
Offline damoegan
« Reply #12 on: November 04, 2012, 04:03:59 pm »
Will try a new switch then, thanks Ed  :happy2:
Offline damoegan
« Reply #13 on: November 04, 2012, 07:06:22 pm »
Just been back out in the car so tryed them again, they worked  :confused:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #14 on: November 04, 2012, 07:20:26 pm »
probably a wiring issue, keep an eye on them
