Author Topic: poor MPG STILL... after changing so many parts  (Read 17585 times)
Offline jedi-knight83
  • -Receive: 41
Re: poor MPG STILL... after changing so many parts
« Reply #30 on: November 09, 2012, 07:44:09 pm »
Ok. Just performed a basic setting. Will see if that changes anything
Also happy to report there were no new fault codes :)
I checked the fuel trims on block 32 aswell
I think that's a bit outside the recommended 10%?
Whose map are you running and with what intake?
R-Tech stage 1 and I'm on a stock intake.
« Reply #31 on: November 09, 2012, 07:51:42 pm »
Hmm, I would contact Nick and ask him about those values.
Usually a poor aftermarket intake will give a high partial lambda but you shouldn't see this with a stock intake that has no leaks and with a good maf sensor.
Just an afterthought but when did you last change your air filter?
  • -Receive: 41
« Reply #32 on: November 09, 2012, 07:55:50 pm »
It was a new filter about 1 year ago. Its a pipercross panel.
when you say air leaks.. where should i be checking?
« Reply #33 on: November 09, 2012, 08:18:15 pm »
With the oem setup you really only have two joints, one that attaches to the turbo inlet (secured with a clamp) and at its other end to the airbox that's held secure by 2 clips. It's unlikely that there would be a crack in the plastic connecting tubing but there is a rubber O ring that seals the joint at the air box side that could have dropped off or badly deformed leading to an air leak.
  • -Receive: 41
« Reply #34 on: November 09, 2012, 08:21:06 pm »
I replaced this part recently due to a deformed O ring seal. So its brand new and both seals are also new
« Reply #35 on: November 09, 2012, 08:23:26 pm »
In that case I'm out of ideas..  :ashamed:
Offline 56OctyVRS
  • -Receive: 72
« Reply #36 on: November 09, 2012, 08:28:32 pm »
Have you tried fitting an oe paper panel filter or cleaning the filter?
  • -Receive: 41
« Reply #37 on: November 09, 2012, 08:33:11 pm »
I'll give it a go tomorrow. Anyone know the cleaning process for a pipercross panel :)
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #38 on: November 09, 2012, 08:38:43 pm »
Have you tried replacing the lambda sensor??
That can affect the MPG if it's playing up. You may not get a fault code from it either  :surprised: - could have been damaged the sensor when removing the pre-cat?
Failing that, ring Nick  :grin:
  • -Receive: 41
« Reply #39 on: November 09, 2012, 09:20:52 pm »
No i've not tried that.
Nick suggested trying the MAF sensor. thing is I'm a bit poor at the moment and 'trying' all these sensors means buying new ones and the MAF is over £100 and goodness knows what the other one is... pretty pricey just to try them out?
« Reply #40 on: November 09, 2012, 10:33:51 pm »
If you're out for a run, could you log block 031 for lambda and block 112 for median EGTand post what you get.
Am I right in thinking you removed your precat?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #41 on: November 09, 2012, 10:37:28 pm »
Turbo cars eh  :sad1:
You don't get these problems with N/A engines  :grin:
I'm troubleshooting a misfire at idle, stuttering / surging under load, clicking front suspension, clunking rear suspension and now my clutch is about finished  :signLOL:
« Last Edit: November 09, 2012, 10:39:03 pm by GrayMK5GTI »
Offline vag12
« Reply #42 on: November 10, 2012, 12:41:23 am »
How do I do this logging with vcds? My car is running extremely low mpg and need to find out what the problem is, how do I log 32?
« Reply #43 on: November 10, 2012, 09:43:11 am »
If you have a vcds cable then turn the ignition on (you don't have to start the car )>click select>engine>measuring blocks, type in 032 in the first group box then press go button and the values will pop up like in Jedi's pic.
  • -Receive: 41
« Reply #44 on: November 10, 2012, 11:39:45 am »
I'll have to have a go at this later in the week or next weekend. what kind of run should i log ? a quick A road blast?
Yes pre cat removed.
