Author Topic: can i fit my k04 (maybe a silly question)  (Read 1889 times)
Offline pd9264
« on: November 07, 2012, 06:01:22 pm »
im currently running my k03 at stage 2+.
      if i fit a k04 turbo only and dont fit the s3 injecters just yet. would the car be ok to drive. im going to go stage 3 in a couple of weeks. just want to get the turbo all fitted and ready to go.  :stupid:
Offline 56OctyVRS
  • -Receive: 72
Re: can i fit my k04 (maybe a silly question)
« Reply #1 on: November 07, 2012, 06:58:22 pm »
Id wait until you are ready to go stage 3 and then fit it. The map you have will be for a K03 and not work.  Sammy who used to be on here found out the hard way because his engine went boom!
Offline JMP
« Reply #2 on: November 07, 2012, 08:16:17 pm »
Several people have used revo stage 2 with stock injectors and k04 turbo. As long as you keep the boost settings sensible, I wouldn't expect big problems. Atleast ecu knows the correct amount of fuel its injecting and also the measured air-fuel ratio. Bigger problem would be running S3 injectors with k03 map. I think K04 might also overboost on k03 map if requested boost is high.
There was a person on vortex that run this setup for almost a year, even tracked it with 6-2-9 (b-t-f) settings, (if I recall correctly the numbers). Said that it was running strong and without problems. I would expect this setup to work very well in partial throttle situation when running on closed loop and following lambda. But I dont know for sure what happens during wot, does ecu run open loop and there is a risk of going lean?
Anyway, for your situation it would be perfectly fine to change the turbo and keep settings down at 2-2-9 or similar, or even stock settings until you get injectors and tune for them.
Offline pd9264
« Reply #3 on: November 07, 2012, 09:12:03 pm »
ok thatss good to no. i may fit the turbo and set my revo settings to stock. im not going to be driving far. also when i book it in for the map. i will fit the s3 injectors the day before. il have to drive about 12miles on this setup to the garage. would that be ok if i go nice and steady.
Offline JMP
« Reply #4 on: November 08, 2012, 08:36:00 am »
If it was my car, I would drive it. Just dont go crazy with the gas pedal.
Offline muckipup
  • -Receive: 25
« Reply #5 on: November 08, 2012, 01:59:09 pm »
Yeah, I would look up that story on the forum....I think there is a lesson to be learned there!
