Author Topic: Clutch restrictor  (Read 1093 times)
Offline mkviken
Clutch restrictor
« on: November 07, 2012, 06:43:47 pm »
Has anyone removed the restriction piece from inside the bleed block?
did it improve clutch feel/bite/modulation/control of the clutch?
can it be got to from the top (remove wire clip and bleed nipple part), or does it need to come out from either the hose or gearbox end?
are new o-rings required to refit the bleed block if it removed?
thanks
Offline vRSAlex
  • -Receive: 253
Re: Clutch restrictor
« Reply #1 on: November 07, 2012, 07:39:38 pm »
Done loads of them.  Doesnt really make the feel much different.  Just seems to return better and in theory should allow faster engagement.
I take the bleed block off.  No need for new seals unless they are fooked.
Follow AKS tuning on Facebook
Offline mkviken
« Reply #2 on: November 07, 2012, 11:53:14 pm »
ok thanks
so does it make the car feel more like a normal or is it not really worth bothering with? the GTI clutch is like nothing I've ever driven before - its utter crap
had a test drive of a focus RS last week and i forgot what a proper clutch should feel like.
Offline s2martyn
« Reply #3 on: November 07, 2012, 11:59:48 pm »
just done this,
after replacing clutch with  sachs dmf and kevlar clutch 4 months ago the peddle felt terrible,remove the resrictor and all feels much better
Offline mkviken
« Reply #4 on: November 08, 2012, 04:50:10 pm »
how did you get on bleeding it? was it easier once the restrictor was removed?
