Author Topic: Car originally had RNS510... now it hasn't  (Read 2806 times)
Offline AlexHxC
« on: November 10, 2012, 05:25:16 am »
so the question is do i get another RNS510 or an aftermarket stereo?
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Car originally had RNS510... now it hasn't
« Reply #1 on: November 10, 2012, 09:21:35 am »
Got a pioneer sat nav in mine,some good extras that the vw ones don't have like built in bluetooh.
Offline chrisr763
  • -Receive: 62
« Reply #2 on: November 10, 2012, 09:36:39 am »
I had an RNS510. Unbelievable unit. Only reason I sold is it was faulty. But seriously would recommend it!
Offline chrisr763
  • -Receive: 62
« Reply #3 on: November 10, 2012, 09:36:40 am »
Offline chrisr763
  • -Receive: 62
« Reply #4 on: November 10, 2012, 09:36:47 am »
« Reply #5 on: November 10, 2012, 09:38:06 am »
Serious echo in this thread...   :laugh:
Offline skard
  • -Receive: 245
« Reply #6 on: November 10, 2012, 10:37:49 am »
I have an RNS and can see why people love them.
However I miss the Zenec NC2010 I had before as it had more spec as standard, good dash integration and an exponentially better Nav that lets you have speed camera warnings, even running in the background with Nav turned off.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: November 10, 2012, 10:43:02 am »
RNS all the way, even RNS315
yet have to see an aftermarket radio I like, that's just my opinion
Cluster and Key coding
Location Great Yarmouth
Offline AlexHxC
« Reply #8 on: November 10, 2012, 05:30:28 pm »
the car had it from the factory but now it has an rcd500, i cant understand why somebody would do that lol the cd changer is gone too.
« Reply #9 on: November 10, 2012, 07:03:33 pm »
The rcd500 has a 6 disc changer intergral to it.
Offline Black9
  • -Given: 35
« Reply #10 on: November 10, 2012, 08:49:34 pm »
RNS510 is a great unit. Defo refit one. U can also fit Bluetooth to it. Mines has it & it's great
Offline AlexHxC
« Reply #11 on: November 11, 2012, 07:37:24 pm »
what about if i wanted to run an amp? has the rns got pre outs?
« Reply #12 on: November 11, 2012, 07:58:08 pm »
The rns don't have pre outs-that's the main reason i went for the alpine in the end
Offline Squeeguk
« Reply #13 on: November 11, 2012, 08:48:33 pm »
It doesn't have pre-outs, but I can supply you with a harness which is plug and play into the newer amps which accept hi- level speaker inputs. It means not butchering your stock wiring in any way. This is the way I have done my own demo system and a few others.
Offline SI-R32
  • -Receive: 125
Re: Re: Car originally had RNS510... now it hasn't
« Reply #14 on: November 11, 2012, 09:23:04 pm »
The 510 can have pre outs as such, by some coding it makes the speaker out line level to goto an amp, you just need to do a bit of soldering to put phonos on the wires,  job done check this link out, I've used it on my amp sounds great
http://www.my-gti.com/1411/volkswagen-rns-510-coding-when-installing-with-a-factory-amplifier
