Author Topic: metal tyre valves - pressure sensors?  (Read 920 times)
Offline jimk04
« on: November 10, 2012, 12:37:32 pm »
I need a new valve as one has become damaged.
I have on board pressure warning, do I have special valves or are they just normal.
(17" Monzas by the way!)
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline S2 Ant
  • -Receive: 21
Re: metal tyre valves - pressure sensors?
« Reply #1 on: November 10, 2012, 12:44:08 pm »
The factory pressure warning works off the abs sensors measuring rotation I believe from reading on here previously. I believe there are 2 types of monza wheel and I'm sure one type was a special valve... Could be wrong tho but it's unrelated to pressure either way
Ant
« Reply #2 on: November 10, 2012, 01:09:45 pm »
Yup, the early Monza 2 rims had a special valve that you had to get from VW.
