Author Topic: Edition 30 Retro Fit Cruise Control Problem.  (Read 2879 times)
Offline superchargedpolo
« on: November 12, 2012, 04:23:53 pm »
Hi there.  This is my first post on this site after years of very useful browsing :)
Have a bit of a problem, can anyone help:
I have a 2007 Golf GTi Edition 30 (1K).
It came from the factory with MFD but no cruise control and a standard steering wheel.
I decided to fit cruise control and noticed that my steering wheel control module was a: 1K0-953-549-BC.  This is the only one, according to ross-tech, that “Does Not allow cruise control retro fitting”.  So I managed to source a new steering control module 1K0-953-549-AH as the software level is the same (SW 0070), it’s a Midline and the slip ring is “Type 2” the same as my old module.
I then purchased a new cruise control stalk from VW: 1K0-054-690-A
I did not need to fit the diagnostic wire, as this is pre installed, and after coding via VAGCOM in both the:
16-Steering Wheel (from 0000012 to 0000042) and
01-Engine (from 0403000318070060 to 0403000318070160)
I went for a test drive.  However, for some reason even after clearing the steering fault and resetting the steering angle, the cruise control would not work at all?
I ran the following diagnostics and no faults were found, also the correct coding for the cruise control was present:
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G83N58OW
   Coding: 0403000318070160
   Shop #: WSC 01279 785 00200
   VCID: 3776E34746CB6CA0D0F
No fault code found.
Readiness: 0010 0101
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           036 0070
   Coding: 0000042
   Shop #: WSC 06314 000 00000
   VCID: 78F4207B0B55A3D8195
Does anyone have any ideas.  I am at a loss.
Thanks in advance.
Craig
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Edition 30 Retro Fit Cruise Control Problem.
« Reply #1 on: November 12, 2012, 04:28:13 pm »
is your slip ring is a C version?
I wouldn't have used an AH on a car with BC
Cluster and Key coding
Location Great Yarmouth
« Reply #2 on: November 12, 2012, 04:39:29 pm »
Yes, the slip ring is a "Type 2" C version.
The Control Module itself is from a 2007 Audi S3 that a friend of mine retro fitted a MFSW to, hence the need to change the module, so it should be compatible according to the Ross-Tech FAQ guide.
The only other thing I can think is a faulty stalk from VW? But I would have thought this would throw up a fault code in VAGCOM?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: November 12, 2012, 05:25:32 pm »
the AH cotroller needs a D version slip ring
what sw hw did the bc have?
« Reply #4 on: November 12, 2012, 09:22:04 pm »
I thought either slip ring would be okay.  I did have to re calibrate but the fault went after that.
Either way, I just swapped back to the BC control box and the cruise works fine now :)
Not sure why the AH didn't work as the SW version was the same 0070, a bit annoying but all sorted now.
Craig
