Author Topic: Help changing front pads cupra?  (Read 1219 times)
Offline Sam89
« on: November 13, 2012, 10:53:05 am »
Is there a how to guide on this, I have a cupra k1 so I have the big calipers,
How do I take the calipers off to change the pads?
Cheers sam
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=9bcoqbdubfjk4me888hfcjdgi5&/topic,19740.0.html
Re: Help changing front pads cupra?
« Reply #1 on: November 13, 2012, 11:00:24 am »
On the back on the caliper there should be 2 plastic caps... remove those and use a 7mm hex socket to remove the guide pins. You then should be able to put the caliper off the carrier, pull the pads out and install the new ones.  :happy2:
Offline Sam89
« Reply #2 on: November 13, 2012, 11:09:49 am »
Thanks mate!
I just wasn't sure on which bolts to remove, sure ill crack it now   :happy2:
« Reply #3 on: November 13, 2012, 12:40:58 pm »
Some useful info for you here; http://www.seatcupra.net/forums/showthread.php?t=192247
**Edit
Dan is going to find the pics on his PC that have been dropped as the hosting account is no longer active
« Last Edit: November 13, 2012, 12:49:06 pm by Tfsi_Mike »
Offline Sam89
« Reply #4 on: November 13, 2012, 04:44:02 pm »
Thanks guys!
Got these fitted today took me less than an hour,
Only thing I found was the pads I had bought had wear sensors and my old pads don't and I couldn't find anywhere to connect it to?
Ended up chopping the wire off, alls fine tho  :happy2:
« Reply #5 on: November 13, 2012, 05:32:09 pm »
Should be on the passenger side. There is a 2 wire loom which come out of the arch to the right of the suspension strut, where one cable is the ABS and one cable is the wear sensor.  :happy2:
