Author Topic: uneven tyre wear  (Read 913 times)
Offline bushypad
  • -Given: 18
uneven tyre wear
« on: November 13, 2012, 05:39:52 pm »
Hi guys getting my tyres replaced and to my shock the wear was extremely uneven the inners were almost bald and outer still had some tread left. I have a feeling this could be down to bushes that need placing.. any idea how much new bushes could cost me including fitting?! bit new to all this any help would be appreciated!
I drive a mk5 gti
Offline Baz300
Re: uneven tyre wear
« Reply #1 on: November 13, 2012, 06:07:33 pm »
It could just be bad wheel alinment
Best to get a garage to check over all the bushes/suspension parts
If they are all good get a 4 wheel alinment ASAP so that your new tyres don't go the same way
Offline bushypad
  • -Given: 18
« Reply #2 on: November 13, 2012, 09:46:02 pm »
Im pretty sure its the bushes because last time i had a service im sure they put them on as an advisory to be replaced.. Any idea howmuch they would cost fitting included?!
Offline Baz300
« Reply #3 on: November 13, 2012, 11:22:57 pm »
Not sure as I haven't had to replace any bushes on mine
But if I do replace any they will be getting poly bushes fitted so that I never have to change them again
« Reply #4 on: November 13, 2012, 11:27:08 pm »
same route i will be going down as well
Offline swgti
  • -Given: 28
« Reply #5 on: November 14, 2012, 07:18:24 am »
Are you talking front or rear? From info I've gathered on the subject and mk5's if its the front get your tracking/allingment sorted if its the rears it can be quite "normal"....I've gone with directional instead of assymetrics on the rears now so that I can swap them round when this starts to show again.
http://www.mk5golfgti.co.uk/forum/index.php/topic,42175.msg492215.html#msg492215
