Author Topic: iPhone 5 on MDI kit  (Read 3287 times)
Offline Baz300
iPhone 5 on MDI kit
« on: November 13, 2012, 11:21:22 pm »
Has anyone tried an iPhone 5 with the connector adaptor in a MDI kit yet?
I'm tempted to fit the kit as when I'm streaming music from my phone through Bluetooth I have to change albums and tracks from the phone rather than through the head unit or steering wheel buttons
Offline Lone_Par
Re: iPhone 5 on MDI kit
« Reply #1 on: November 13, 2012, 11:40:50 pm »
Probably doesn't answer your question, but I've not read the whole article....
http://www.tuaw.com/2012/11/09/testing-iphone-5-connection-adapters-with-an-volkswagen/
Offline Baz300
« Reply #2 on: November 13, 2012, 11:47:00 pm »
Doesn't look promising as I need Bluetooth switched on for any phone calls in the car
Might just have to stop buying my music from apple so I can put the mp3s directly onto the SD card without messing about
Offline skard
  • -Receive: 245
« Reply #3 on: November 14, 2012, 05:19:20 am »
I got a genuine lightning adaptor in the armrest MDI. Charged and played music
Offline Lone_Par
« Reply #4 on: November 14, 2012, 07:00:16 am »
That's the problem I have with my current head unit. Can plug my phone in using the dock connector but you have to change channel to iPod input from Bluetooth audio so you lose the call functionality (I think). So I've just went for straight Bluetooth and have some bits to make a dock connection in my ashtray!
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #5 on: November 14, 2012, 07:33:12 am »
Upgrade your firmware of your headunit and i think the problem is sorted! I had the same problem but upgraded to 4120 and now my mfsw skips the tracks when playing music through bluetooth. PM Golfman and ask, certainly alot cheaper than an mdi kit too
Offline Baz300
« Reply #6 on: November 14, 2012, 08:42:19 am »
I have a rcd510 don't think the firmwear can be upgraded
Offline Dp_Ed30
« Reply #7 on: November 14, 2012, 10:09:12 am »
its not the fw for the unit, its for the can gateway.
i did a total update that made the BT info work but dimmed the backlight on my unit, then went to a modified rcd510 fw that updated the head unit but left the old can gateway sw.
dim screen solved but lost BT track info
Offline Baz300
« Reply #8 on: November 14, 2012, 11:00:12 am »
How did you update the firmware?
I have an A revision Rcd but thought the bt track was only available on a B revision
Offline Lone_Par
« Reply #9 on: November 14, 2012, 11:13:16 am »
I know there are generally issues with BT track info, changing/pausing tracks etc across platforms after the upgrade to ios6. My pioneer unit used to, but can no longer change tracks etc. Waiting for pioneer to issue a firmware update.
Offline Baz300
« Reply #10 on: November 14, 2012, 11:19:51 am »
There is a new iOS upgrade available perhaps this will fix the bugs
I still cannot get it as every time I try to download it my bt Internet just crashes (only does it when I try to download from iTunes)
Will try taking my laptop to work next week to see if I can download it from there
Offline Lone_Par
« Reply #11 on: November 14, 2012, 11:31:58 am »
Afraid it doesn't, if your mean 6.01 as that's what I'm running. They beta 6.1 is with developers though so it might get resolved when that's released. Wouldn't hold your breath though as I'm sure Apple will say its up to other manufacturers to catch up/update.
Offline Mikeygtir
« Reply #12 on: November 22, 2012, 04:19:32 pm »
i'm missed the point of the post.. but ive got a rev H RNS510 with MDI and i just purchased an apple 30-lightning adaptor from comet and using the MDI-Ipod cable the MDI on my iPhone 5 works superbly..
« Reply #13 on: November 22, 2012, 05:03:23 pm »
Ive got an RNS-510 Unit version H and 9W7 bluetooth and its the dogs danglies! No messing with wire, track info on screen, control the phone from the dash or steering wheel. Move away from the cables guys! Bluetooth is the future! :)
Offline Luka
« Reply #14 on: November 22, 2012, 07:08:48 pm »
Does that unit display on the red highline?
Sold - 2006 Tornado Red GTI 3dr
