Author Topic: RCD 510 info please  (Read 788 times)
Offline Clarkee200
RCD 510 info please
« on: November 14, 2012, 07:31:50 pm »
Hi
My rcd510 arrived from ebay today. Can anyone shed any light on the firmware and if I will need a canbus adaptor for my 2005 gti
Re: RCD 510 info please
« Reply #1 on: November 14, 2012, 07:41:48 pm »
I would first find out what version gateway you have installed as in all likelyhood you will need an updated one to avoid battery drain.
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #2 on: November 17, 2012, 10:07:07 pm »
Most likely will need a new gateway unless you have the sound pack upgrade which has the amp under the passenger seat- my 55 plate does and that seems to turn everything off so no drain.
If you plug in the headunit and hold down the setup button for about 5 to 10 seconds you can then get to the screen that has the system info
