Author Topic: Confused rcd510  (Read 3667 times)
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Confused rcd510
« on: November 14, 2012, 07:40:40 pm »
I'm looking to buy a rcd510 probably without DAB but i will be getting a built in hands free Bluetooth module fitted to it but not sure which 1 I need to work with all iPhones?
I'm done some research but I still don't know
GTI Pirelli - Reflex Silver - 5dr - 58 - B12 Sportline kit!
Sold ~ GTI - Mk5 - Pearl Black -  Bluefin - 3dr - 08
Offline Baz300
Re: Confused rcd510
« Reply #1 on: November 15, 2012, 08:28:47 am »
I have one of these http://www.mk5golfgti.co.uk/forum/index.php/topic,51013.0.html
And it worked with my iPhone 4 and 5
Offline rsreid2000
Re: Confused rcd510
« Reply #2 on: November 15, 2012, 08:35:15 am »
I also have this unit and works great with my iphone 4s.
Also fitted myself, quite easy following the guide on here.
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: Confused rcd510
« Reply #3 on: November 15, 2012, 02:21:26 pm »
Nice thanks for the help, there a bit more than I thought they would be to be honest
Is it hidden I don't have any steering wheel controls so how would I answer the call?
Offline rsreid2000
Re: Confused rcd510
« Reply #4 on: November 15, 2012, 02:27:05 pm »
I have the RNS and you answer by touching the screen.
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: Confused rcd510
« Reply #5 on: November 15, 2012, 05:03:55 pm »
Ah cool just this minute brought a RCD510 I'll fit it as soon as i get it i take its just plug and play I have an 08 GTI?
Offline Baz300
Re: Confused rcd510
« Reply #6 on: November 15, 2012, 05:50:49 pm »
What age is your car? As you might also need a new can gateway to stop the stereo from draining the battery when the car is not in use
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: Confused rcd510
« Reply #7 on: November 15, 2012, 05:54:36 pm »
You should be safe with an 08
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: Confused rcd510
« Reply #8 on: November 15, 2012, 05:55:50 pm »
Good good will save me a few quid then.
.....but whet will happen to my iPod connection in the glove box will this still work?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: Confused rcd510
« Reply #9 on: November 15, 2012, 05:59:40 pm »
Can steam music using bluetooth but it should still work
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: Confused rcd510
« Reply #10 on: November 15, 2012, 10:44:02 pm »
This is true just wanted to know if I needed to remove it from the glove box but I hope it does still work.
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: Confused rcd510
« Reply #11 on: November 17, 2012, 10:02:23 pm »
You will be able to use the iPod still, just plug it into the back of the RCD510
Oh and the Bluetooth kit on that link is ace, I have it with my rcd510 and rate is very highly
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: Confused rcd510
« Reply #12 on: November 23, 2012, 06:18:59 pm »
Think I'll get the Bluetooth module but may have to wait with Christmas coming up.
I wasn't sure whether to start a new thread but my RCD510 has arrived today and looks mint but is it just plug and play correct me if I'm wrong but all I need is a T20 torx screwdriver?
I've seen a vid on YouTube but it doesn't have the vent on the top of the dashboard like mine, just the tray???
I have a 08 Gti
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: Confused rcd510
« Reply #13 on: November 23, 2012, 06:52:02 pm »
Yep just the torx screw driver and some trim removal tools would be handy just to not damage the plastic but not essential
For the too vent gently lift it up around the edges and it will come out leaving you with a lower tray that has the wheel for the top vent in it. There is a screw right at the back the holds this in. Remove this then left that section up to show the front facia fins where the other two screws are. The rest should be like your video  :happy2:
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: Confused rcd510
« Reply #14 on: November 23, 2012, 09:10:39 pm »
Thank you
I'll attempt it over the weekend but I only have a screw drivers to remove the panels but I suppose I'll just have to be gentle.
