Author Topic: Updating to V9 Maps RNS 510  (Read 14229 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« on: November 15, 2012, 10:20:39 am »
Hi everyone,
Trying to upgrade a RNS 510 for a member on here and is having a weird problem.
He has a version B unit which had 2680fw on it, upgraded it to 3810. he already has his canbus upgraded so no battery drain issue there.
He had Map version 7377 and tried upgrading to v9 and it takes a few hours to do. When the progress bar gets to the end it goes back to the beggining again and loads again
now heres the tricky bit
Ive also got a version B with the same FW. Mine done it in around an hour. However I upgraded from v8 to V9.
I do remember when my canbus was an older version and tried upgrading to V8 it also took very long (3 hours!) the progress bar kept restarting.
What could be the issue? My RNS unit works perfectly with 3810 and V9 maps. His one takes ages,
Could it be that he is upgrading from V7 straight to V9 ? and not V7 to V8 to V9?
Thanks for any help.
Raz
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Updating to V9 Maps RNS 510
« Reply #1 on: November 15, 2012, 10:27:22 am »
The drive doesn't like the disc
use a genuine disc
Ed
Cluster and Key coding
Location Great Yarmouth
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #2 on: November 15, 2012, 10:28:46 am »
use a genuine disc
Ed
Thanks Ed,
I used the same make Disc as i used on my car, Verbatim DL disc burnt at slowest speed. mine worked fine. Should I burn it again you think?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: November 15, 2012, 10:46:52 am »
makes no difference, if it worked on yours and many others. If the drive in the unit doesn't like the disk then it won't install.
I had a unit, tried loads of copy disks, none worked. Used the genuine disk and installed first time
« Reply #4 on: November 15, 2012, 11:06:03 am »
Apparently it makes a difference on what make and type of rewriter you use to produce the disc in addition to using the best dvd discs and burning at a slow speed.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: November 15, 2012, 11:21:12 am »
Ive always used my sony laptop to make FW and Maps discs. Ive made Eastern Europe V8 and UK v8 and V9 maps. they all have worked with no problems.
Going to give it another try and leave the disc for a few rounds, as this is how i updated mine when i did V8. Eventually it loaded onto the hard drive. but took 3 hours.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: November 15, 2012, 11:29:04 am »
what part of what i said don't you grasp
you could burn loads of disks that work on your drive and many others. If the drive doesn't like it, it won't install.
it will install to a point and keep cycling round and restarting.
Solution = Genuine disk or change the drive
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: November 15, 2012, 12:08:58 pm »
lol I thought there may be hope somewhere with the discs I have
cheers ed  :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: November 15, 2012, 12:24:09 pm »
i would have liked a simple cheap option too, had to buy a genuine disk
Offline PND
  • -Receive: 62
« Reply #9 on: November 20, 2012, 07:12:31 pm »
Update...
All now sorted - another copy of the DVD did the job first time.  :happy2:
Cheers Raz.  :drinking:
« Reply #10 on: November 20, 2012, 07:20:10 pm »
Since I can't see the V9 maps being released offically in Germany, are these downloaded V9 maps actually the real deal?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: November 20, 2012, 07:29:22 pm »
i think it has just been released :happy2:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #12 on: November 21, 2012, 10:01:01 am »
Update...
Youre welcome Mate.
Ryanedition30
« Reply #13 on: August 12, 2013, 08:52:16 am »
Hello Guys,
I have a 5+GB ISO Of V9 Maps on my pc, but i cant work out how to burn it, my DVD Discs are 4.7GB.
Does anyone know how to do this? or How i have to burn the maps, I updated my firmware and now Maps and i think HDD isnt working (unless it wiped my HDD of songs.)
new firmware info
HW Version - H74
SW Version - 3810
Delivery Part No - 1T0035680D
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: Updating to V9 Maps RNS 510
« Reply #14 on: August 12, 2013, 09:05:01 am »
You need a dual layer dvd. They are around 8gb. Buy a verbatim one.
Sent From My Samsung S3
