Author Topic: Upgrading a DSG steering wheel - is there a guide?  (Read 1574 times)
Offline Ess_Three
« on: November 15, 2012, 10:29:23 am »
Folks,
Is there a guide to changing the steering wheel on a DSG car?
The car has a standard steering wheel...I'm looking to upgrade to one with paddles.
Any guidance on the site anywhere. I tried a search but had no luck.
Also, can a multi-function + paddles wheel be fitted?
Or how about a Mk6 GTI multi-function with paddles wheel?
Finally, would a multi-function steering wheel of any style, work with an RNS510?
Any/all the answers will be greatly appreciated, thanks.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Upgrading a DSG steering wheel - is there a guide?
« Reply #1 on: November 15, 2012, 12:21:04 pm »
1. Yes a MFSW with paddles can be fitted
2. Yes a Mk6 MFSW can be fitted but you will need to upgrade alot more parts
3. Depending on the year of your car, depends on which buttons you need!
I used a guide from somewhere but cant remember where when i fitted mine
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #2 on: November 15, 2012, 12:25:23 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,35449.0.html
Scroll down a bit and thats how you take the wheel off
Offline Ess_Three
« Reply #3 on: November 15, 2012, 08:50:21 pm »
Thanks for that...very useful.  :happy2:
Offline GLIDN
« Reply #4 on: November 16, 2012, 12:29:30 am »
If you are not comfortable pulling your car apart and have/or know someone with VCDS Hex + Can. Then do not bother swapping parts,
as you will not be able to re-calibrate the G85 steering angle sensor.
Offline Ess_Three
« Reply #5 on: November 17, 2012, 07:40:58 am »
Good advice there  :happy2:
I'm happy to rip the car apart and do the work, and I have VCDS...I'm just not sure if the result will justifty the effort.
It could get expensive if fitting a lot of parts/controllers together.
