November 16, 2024, 12:59:31 pm
All Things Mk5
Mk5 General Area
Canbus Gateway Location in 2008 1.9TDI
Topic: Canbus Gateway Location in 2008 1.9TDI (Read 2581 times)
bakili
Always Involved
-Given: 6
-Receive: 11
November 17, 2012, 08:29:10 am »
Hey guys
I am going to fit Polar FIS hopefully today.
Can you please advice where canbus gateway located in 1.9TDI Golf 2008
dont really need removing it, just need access to unplug and plug Polar FIS.
RetroRaz
Just look at my post count
-Given: 32
-Receive: 194
Re: Canbus Gateway Location in 2008 1.9TDI
Reply #1 on:
November 17, 2012, 10:32:08 am »
In my 05 Tdi it was above the clutch pedal which was a pain to get into. Or it sometimes can be behind the ciggarette ashtray.
#RetroRaz -
https://instagram.com/retroraz/
bacillus
-Given: 4
-Receive: 451
Reply #2 on:
November 17, 2012, 10:54:47 am »
Quote from: vw55raz on November 17, 2012, 10:32:08 am
If this is the case, using a small screwdriver or plastic wedge, squeeze in the gearstick gator surround and it will lift-out. You’ll then see 2 torx screws holding the ashrtray assembly in. Remove these and lift up the ashtray. You’ll have to unplug the cigarette lighter cable and unclip the cable restraint.
You should be able to see a red plug at the back of where the tray was. This is the CAN Gateway
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Reply #3 on:
November 17, 2012, 10:57:03 am »
on a 2008
it is behind the relay plate
Remove the Cubby bin under the light switch
Unclip the relay carrier and move to one side
Look at the back for the RED PLUG / some have a BLUE plug on a skoda
Unplug it and lift the gateway out
refit new gateway
http://www.r32oc.com/tutorials-guides/30166-canbus-gateway-location-removal.html
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
bacillus
-Given: 4
-Receive: 451
Reply #4 on:
November 17, 2012, 01:14:32 pm »
If the polar is going to sit in an awkward position for getting to it, can I suggest you update its firmware to the latest available one from the Polar website before you install it.
All Things Mk5
Mk5 General Area
